Need slack in Clutch Cable and Brake Line - Road Glide Forums
post #1 of 5 (permalink) Old 04-16-2016, 08:12 AM Thread Starter
bosshogg123's Avatar
Hey Guys, I am finishing installation of a set of Stretch Heritage bars from Heritage bars (13 RGU), and I can use a little bit of slack in the clutch cable and front brake line. Any suggestions on where I can get it from? Thanks!
bosshogg123 is offline
post #2 of 5 (permalink) Old 04-16-2016, 08:21 AM
RICKLB58's Avatar
Don't know the size of those bars but when I put on my 12 inch Malo bar I ran the clutch cable behind the highway bar it fits fine just its rerouted a little, the brake line I cut a wire tie holding the brake line and moved the tie back an inch or 2 its a little tighter but is working no issues
https://scontent.ford1-1.fna.fbcdn.n...af&oe=57BF63DF
2012 RGU, Thunder Max tuner, V/H power duals, Stage one, DayMakers, 12 inch F47 Malos, custom gages, and some extra chrome.
RICKLB58 is offline
post #3 of 5 (permalink) Old 04-16-2016, 11:10 AM Thread Starter
Here's what it looks like mid-job. The KhromeWerks Stretch Heritage bars are a little longer than the Heritage bars but maintain the shape. I found and cut the wire tie for the brake line and next I'm going to re-route the clutch cable as you recommend, thanks! I'll take pics before and after and post them later...
post #4 of 5 (permalink) Old 04-16-2016, 07:38 PM Thread Starter
To re-route the clutch cable would have required complete disassembly, so I made a small modification to the plastic along the fork:
I was also having trouble getting the clamp tight, so I followed some other advice and drilled some access to the bottom clamp bolts:
I have the clamp bolts as tight as I dare go, and if I push down on the bars really hard they still move a little, any suggestions to secure them, like a shim in the clamp over the knurled areas?
Also, the start switch on the clutch handle is not engaging fully, so I have to start it in neutral. I checked the alignment and it's aligned properly with the left switch housing. Is there a piece missing?
Other than these minor nits, love the new bars!
post #5 of 5 (permalink) Old 04-18-2016, 07:59 AM Thread Starter
I ended up ordering an LA Choppers riser clamp assembly LA-7415-01 that I found new on EBay for $79.95 (open package) and a set of Arlen Ness bushings.
My clutch interlock switch is not engaging with the clutch and have to start in neutral; any suggestions on this?
Thanks!
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Brake line slack for 14" apes hazinthehides Aftermarket Accessories 5 05-17-2017 08:57 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Stock clutch cable & brake line. Came off a 13 ultra. 100.00 or best offer. neverdone Parts for Sale 0 05-15-2014 03:39 AM
Stock Clutch Cable and top ABS line length? lgsmith Controls & Handlebars 2 01-14-2014 08:37 PM
