Newbie Question - Road Glide Forums
post #1 of 7 (permalink) Old 12-20-2012, 07:09 PM Thread Starter
justincollins's Avatar
Newbie Question
Ok so I have a 05 glide and am changing the grips but have discovered its not so easy with the dual cables instead of electronic. My question is is it hard to do the throttle adjustment after getting the new grips on. Any help would be great
justincollins is offline
post #2 of 7 (permalink) Old 12-20-2012, 08:44 PM
caboverbob's Avatar
Pc. o' cake
It's been a few years since I've done it, but it is very simple. Use the adjusters to create slack and allow removal of cable from grip, re-install ferrules onto new grip, take the slack back out being careful not to tighten either one too much.
caboverbob is offline
post #3 of 7 (permalink) Old 12-20-2012, 08:50 PM
Ironrider's Avatar
Take your time loosen up the switch housing look how the cables are attached pull it apart and put the new ones on.
Sent from my MB860 using Motorcycle.com Free App
Ironrider
Ironrider is offline
post #4 of 7 (permalink) Old 12-20-2012, 09:32 PM
Shark of the Month August 13
SIC_26's Avatar
Exactly what everyone above said......When you are done reinstalling everything, pop the A/C off and make sure that at wide open throttle (at the grip) the throttle body/carb is fully open, if not readjust accordingly
SIC_26 is offline
post #5 of 7 (permalink) Old 12-20-2012, 09:49 PM
And take care to get the front brake light switch positioned under the lever correctly or your next question will be "why does my brake light stay on?"
SickRick is offline
post #6 of 7 (permalink) Old 12-21-2012, 06:37 AM
mocotom's Avatar
Exactly what SickRick said! You can cut a 3/8 inch strip of cardboard and place it in the opening at the brake lever pivot point. The opening I refer to will appear when you pull the lever. Purpose is to hold the lever back slightly so you don't snap the end off of the brake light switch when you reassemble the housing.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #7 of 7 (permalink) Old 12-21-2012, 07:52 AM
BDMastiff's Avatar
Yes on what everyone else said. Also, I usually struggle a bit with the nubs on the end of the cable that slip into the grip. Take your time and be patient and you'll have no problem.
1996 Fatboy
BDMastiff is offline
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
Newbie question, comparison of Mustang, Maverick, Sundowner dawgcasa Seating: seats, backrests 10 05-26-2012 09:16 PM
Question from a newbie on '12 RG Custom pricing dawgcasa *General Road Glide Discussions/Pictures 19 04-17-2012 03:03 PM
Newbie exhaust & intake question... mjohnson68 Intake and Exhaust 14 02-20-2012 07:19 PM
Newbie warranty question musicman8120 *General Road Glide Discussions/Pictures 4 08-19-2010 05:53 PM
