throttle by wire question - Road Glide Forums
post #1 of 11 (permalink) Old 12-21-2012, 05:18 PM Thread Starter
I recently got my new bars all done and back together. My question is i dont feel like i got a fast throttle response like i did.It may just be me but was wondering if anyone has had theis problem? My connector is together but inside the bars.I have the road six apes so i can actually still see the green bastard lol.It looks together and not at all tight in the bar.Any ideas would be appreciated.....
suicidecj5 is offline
post #2 of 11 (permalink) Old 12-21-2012, 06:22 PM
If it was loose it would throw trouble codes and more than likely go into limp mode.
I wrapped my connector with electrical tape before reinstalling.
Big_gary is online now
post #3 of 11 (permalink) Old 12-21-2012, 10:41 PM
There is a throttle relearn procedure you could try. I had a different issue with mine but it worked. Unfortunately i dont remember exactly how to do it. Hopefully someone will chime in or you could ask your dealer
post #4 of 11 (permalink) Old 12-22-2012, 06:18 PM Thread Starter
well no codes and no limp mode so maybe ok i guess idk
post #5 of 11 (permalink) Old 12-22-2012, 06:36 PM
Could it be mechanical. Before you laugh... I know it's throttle by wire. Read on.
Put Wild 1 Chubby on my bike, 2011 FLTRUSE. AFTER all the wires are in the bars, which is damn near impossible when you have heated grips and GPS!!!
Anyway, after that, found out the throttle side is .035" "egg shaped". Talk about pissin' me off!!! Net result is a sensation like it's lost throttle response! The throttle is NOT smooth. Sticking a bit even after trying to take the high side down a bit. Didn't go too far because it will rust.
REALLY hope this is NOT your problem!!!
Gonna ride mine awhile and see if it loosens up a bit.
Good Luck!
FGOWI is offline
post #6 of 11 (permalink) Old 12-25-2012, 09:17 PM
TLKurtz's Avatar
Send a message via Skype™ to TLKurtz
I had problems with mine after installing new bars. Unlike yours, mine actually gave a P1510 trouble code. I did a lot of reading on this, and if I recall correctly there were others that reported "slower" throttle response. I know for mine throttle response was quite a bit slower. I cut the connector out and straight-wired the entire thing from the twist grip sensor down to the connector in the fairing. I left myself another 12"-18" of coiled up slack inside the fairing in case the TGS ever goes bad I can easily pull it, cut it off, wire a new one in, and be done.
After getting rid of the connector my code issue disappeared and throttle response is snappier than when new!
-TLKurtz (Mr. Wizard) - Blackhorse Cavalry Nomads VMG member (2/11 CAV - East/West German Border)
2015 RGS - Vivid Black and loads of fun.
Reside in Vegas. I keep cold beer in the fridge for all visitors.
TLKurtz is offline
post #7 of 11 (permalink) Old 12-25-2012, 11:13 PM
Easyryder01's Avatar
Watching this thread.
2017 RGS Velocity Red
Easyryder01 is offline
post #8 of 11 (permalink) Old 12-25-2012, 11:39 PM
Murlsquirl's Avatar
Cut off the plug and solder the wires. Problem solved.
Murlsquirl is offline
post #9 of 11 (permalink) Old 12-27-2012, 08:12 PM Thread Starter
thanks for the replies. i got three codes p1510 p2127 and p2138 all seem to be the green plug.Correct me if anyone thinks i am wrong...
post #10 of 11 (permalink) Old 01-03-2013, 09:08 PM
TLKurtz's Avatar
Best way to find out is eliminate the green plug!
TLKurtz is offline
throttle by wire harness ???? flatblackbastard Controls & Handlebars 15 06-24-2012 08:02 PM
Throttle by wire roaddog Troubleshooting for Road Glides 31 05-09-2012 12:14 PM
Throttle by wire craigv65 Controls & Handlebars 2 03-24-2012 10:52 PM
Throttle By Wire Hullhorr Classifieds Archive (3 months old+) 1 01-12-2012 04:24 PM
Need Throttle by wire help harley75 Controls & Handlebars 2 08-11-2010 10:45 PM
