2017 Heated Grip Install - Road Glide Forums
 3Likes
post #1 of 33 (permalink) Old 02-09-2017, 01:50 PM Thread Starter
I'm trying to install a set of the HD heated grips (plain ones that come on the Ulra Limited) and have run into a problem with the wiring. I searched this site, but found only older post, and it seems that the wiring is different for a 2017. It appears that the accessory lead for the front of the bike is under the fairing, near the right turn signal connector. I watched a video on YouTube and the guy said all the wiring was under the instrument cluster, near the handle bars. He had already had the bike back together, and did not elaborate on where the wire was, what color combo it had, or even go over how the accessory wiring was connected to the battery. After an exhaustive search, I did not see any connectors under my instrument panel, and I have yet to tackle wiring the accessory plug to the battery. Has anyone tried to wire up a set on a 2017 Ultra?
Thanks in advance.
Rick
rdm197apd is offline
post #2 of 33 (permalink) Old 02-09-2017, 02:16 PM
Cali-rider's Avatar
Thanks in advance.
Rick
This might help
https://www.youtube.com/watch?v=ZGqLy_EzbUg
" You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose" - Dr. Seuss
Cali-rider is offline
post #3 of 33 (permalink) Old 02-09-2017, 02:19 PM
Cali-rider's Avatar
Thanks in advance.
Rick
More
https://www.youtube.com/watch?v=rf2CQ7OWdDY
Remove faring-
https://www.youtube.com/watch?v=BvwSsWefj9A&t=14s
post #4 of 33 (permalink) Old 02-09-2017, 03:52 PM
kevinckb3's Avatar
I had the dealer install those on my 17 so I know it can be done
kevinckb3 is offline
post #5 of 33 (permalink) Old 02-10-2017, 11:47 AM Thread Starter
Heated Grips
Thanks for the links, but the video by Law Abiding Biker was made in 2015. The bikes electrical is different for the 2017s, according to what I have read and been told. I was informed of the change by the stealership, so they may just be saying that to get me to have them do the install. I was able to get the fairing off with no issues.
post #6 of 33 (permalink) Old 02-10-2017, 12:06 PM
You might want to watch this video. It is for a 2017 SGS but may prove helpful. https://youtu.be/E94qcAJr4Jk
macabra11 is online now
post #7 of 33 (permalink) Old 02-10-2017, 01:38 PM
There is a plug under your speedo panel. On left side violet and black wires, it has an empty male plug clipped on to it. It's not very long is for heated grips!
Skeezicsglide is offline
post #8 of 33 (permalink) Old 02-10-2017, 02:22 PM Thread Starter
Awesome, I'll take another look this weekend.
post #9 of 33 (permalink) Old 02-12-2017, 09:54 PM
steadfast's Avatar
How you making out with this? Reason I ask is I found a deal on some heated grips that were pulled off of a 2016 ultra classic limited and was hoping it would be a plug and play for my 2017 RGS
"WE RODE HARD.........AND IT WAS GOOD"
2017 FLTRXS, 2001 FLHT - 2001 Hayabusa- KTM 690, 1989 FXRS, 1976 FXE, 1979 XLCH, A few Yammy XS650's
steadfast is offline
post #10 of 33 (permalink) Old 02-13-2017, 07:18 AM
twowheeladdict's Avatar
I haven't done my '17 Road King yet, but on my '16 Ultra I bought the basic black heated grips and ran the wires internal. The right side already has the wiring running into the speedo cluster area. You pull the wires for the left grip and connect one of the leads to the one you find in the cluster. That puts power to both grips. Then the other lead has to get 12v power from somewhere.
I ran the wire into the fairing but it wasn't long enough to reach the 12V accessory outlet. Instead I traced the wires going to the 12V accessory outlet back up into the middle of the fairing and used Posi-tap connectors to connect power.
I could have gone under the tank and connected to the accessory power harness I added for the heated seat.
Since I am also mounting my Garmin 660 on the Road King, I may run the power for the grips to the accessory power harness under the seat along with the GPS power, or I may pick up power from inside the headlight.
twowheeladdict is offline
HD Heated Grip Install on 2015 RG (with pictures) michigander Do-IT-Yourself 39 11-22-2018 05:34 AM
2017 Heated grip install question? ashnic Controls & Handlebars 3 05-01-2017 02:29 AM
Iron Aces Rushmore Road Glide Mount w/X-Grip and RAM Finger Grip Bunker Parts for Sale 6 04-06-2017 01:24 PM
Heated Grip Install!! HELP ME!!! 1BadGlide Do-IT-Yourself 2 05-12-2013 06:58 PM
Heated Grip install. 488pipefitter Aftermarket Accessories 3 06-04-2011 07:01 PM
