Heated grips question - Road Glide Forums
post #1 of 5 (permalink) Old 02-11-2017, 10:22 AM Thread Starter
Can I put stock harley heated grips from an ultra 2004 on my 17 glide? They have plugs obviously and are standard so I was hoping they plugged into existing wiring harness
phill is offline
post #2 of 5 (permalink) Old 02-11-2017, 11:01 AM
twowheeladdict's Avatar
I am amazed those grips are still working at almost 13 years old and not showing visible signs of wear.
You could stop in at your local dealer and compare them to a kit designed for the '17 Road Glide and determine it that way if no one has personal experience to share.
twowheeladdict is offline
post #3 of 5 (permalink) Old 02-12-2017, 07:27 AM
steadfast's Avatar
Probably not designed for internal wiring though? Could definitely make them work if not but would have to run the wiring on the outside of the bars
steadfast is offline
post #4 of 5 (permalink) Old 02-12-2017, 08:41 AM
mastergunnera8's Avatar
I wish they made PM type grips (fat middle) for rushmores..I didnt see any in the catalog. I tried a rental bike with them and they were nice...
Looks like the heated ones in the catalog are 08-up....
mastergunnera8 is offline
post #5 of 5 (permalink) Old 02-12-2017, 08:59 AM
BlazingSaddle's Avatar
For starters, you have to look at is whether your 2004 is throttle by wire, as well as difference in diameter of handlebar between the 04 and your 17. I don't know the answer to either, but not too hard to look up and/or measure.
BlazingSaddle is offline
Heated grips question railer60 Controls & Handlebars 2 01-18-2018 12:49 PM
Heated Grips Vs. Heated Gloves Big Spoon Aftermarket Accessories 24 12-26-2016 09:36 PM
Wiring question - Swapping HD heated grips to Heat Demons 2012FLTRU_BigBlue Controls & Handlebars 1 04-11-2015 07:04 AM
Heated Gloves or Heated Grips BlackDangerous Clothing 50 05-02-2013 09:10 PM
Heated Grips vs Heated Gloves? sojourner Aftermarket Accessories 10 06-09-2010 01:02 PM
