2017 RGS handlebar adjustment? - Road Glide Forums
 2Likes
  • 1 Post By InlineR
  • 1 Post By flhtcm
post #1 of 9 (permalink) Old 02-12-2017, 05:02 PM Thread Starter
thereal142's Avatar
I've got a new Road Glide Special, and I'd like to roll the handlebars forward a little, and depending how far I can go, possibly roll both lever perches down a little. I know there's a pin in the bar clamp, but does the pin allow for a little adjustment, and if so how much? Also, are there pins in the lever brackets/ switch housings that limit or prevent adjustment there? I like the bars (at least I think I will), but would like to tweak them. I hurt both my shoulders in 2016 and I have some carpal tunnel issues, so in the interest of my comfort I want to give the OEM bars a chance, just in case my body likes 'em.
2017 FLTRXS Laguna Orange, Stage 2 Torque cam, SE Ventilator A/C, V&H Hi-Output Slip-Ons, Tour-Pak, Freedom Shields 12" Touring
thereal142 is offline
post #2 of 9 (permalink) Old 02-12-2017, 05:36 PM
InlineR's Avatar
there is some adjustment in the bar without pushing in the pin. 5-10 degrees is all.. the hand controls have a bit of play as well not much though.
thereal142 likes this.
2017 Harley Davidson Road Glide Aggressor Factory 47 Signature Bars Factory 47 Bag Guards Klockwerks Advan Black Extended Bags Cobra 909
InlineR is offline
post #3 of 9 (permalink) Old 02-12-2017, 09:50 PM
steadfast's Avatar
You can pull the pin and get some more adjustment. I did but not happy with it so am ordering new bars. Search in the forum for it as there is a how to. Yes the perches are pinned as well and those have to be ground down as they are cast.The bar height and width were good it was the pullback i didnt like. Definitely worth the 30 minutes it takes to pull the pin. Vise grips to pull or some guys were tapping it down.
"WE RODE HARD.........AND IT WAS GOOD"
2017 FLTRXS, 2001 FLHT - 2001 Hayabusa- KTM 690, 1989 FXRS, 1976 FXE, 1979 XLCH, A few Yammy XS650's
steadfast is offline
post #4 of 9 (permalink) Old 03-23-2018, 10:19 PM
big papa's Avatar
Is there a video to roll the bars without removing lock?
big papa is offline
post #5 of 9 (permalink) Old 03-23-2018, 10:32 PM
It is not possible to roll the bars forward or backwards without removing the pin. The pin holds it in one position. The pin is easy to remove, pull it out or drive it down.
Buzzy is offline
post #6 of 9 (permalink) Old 03-23-2018, 11:23 PM
ridez's Avatar
Or leave the pin in and just elongate the hole on the bars. That way you have the security of the pin still if you want to keep the pin.
2018 vivid black rgs stage 4, 14 vindikta wildcats, sony xav ax5000, biketronics 2250.14, hertz mille legend 1650.3, hertz mille pro 690.3
ridez is offline
post #7 of 9 (permalink) Old 03-24-2018, 12:33 AM
big papa's Avatar
I know how the pin and rolling works, I wanted to see how to do it all without removing ignition switch...
big papa is offline
post #8 of 9 (permalink) Old 03-24-2018, 09:01 AM
flhtcm's Avatar
Factory 47 has a video for installation of their bars, it shows how to take the Gage cluster without removing the ignition switch.
Sent from my SM-N950U using Tapatalk
madmat likes this.
flhtcm is offline
post #9 of 9 (permalink) Old 03-24-2018, 09:19 AM
madmat's Avatar
This^^^^^
18 RGS Bonneville Salt Pearl
madmat is online now
2017 shock adjustment Neutant Suspensions 1 09-19-2017 02:55 PM
Handlebar adjustment questions. Oldbie Controls & Handlebars 3 09-05-2017 05:05 PM
Rushmore Handlebar Adjustment KevDillow Do-IT-Yourself 13 05-04-2017 09:01 AM
2016 RGS or 2017 RGS? PEZRACER *General Road Glide Discussions/Pictures 11 09-01-2016 02:14 PM
Handlebar adjustment?? bagger51 Controls & Handlebars 7 05-03-2014 03:14 PM
