16" Factory 47 Signature Bar Install - Road Glide Forums
 6Likes
post #1 of 14 (permalink) Old 02-15-2017, 02:48 PM Thread Starter
Cool 16" Factory 47 Signature Bar Install
2016 Road Glide Special FLTRXS
I'm 6'3" and I decided on the 16" version of the Factory 47 Signatue Bar. The stock Schwinn bars gotta go.
That being said...
I don't have the garage, the time or the patience to do the work.
My question to you is: What is the definitive highest quality route for extending the Control Wire, Throttle by Wire, and ABS Brake Cables (am I forgetting anything)? Which aftermarket gear is the best?
Ride safe...
Jason,
Honolulu, HI
Bbally likes this.
Waikikijason is offline
post #2 of 14 (permalink) Old 02-15-2017, 05:29 PM
Khaotic's Avatar
Namz for wiring
Magnum Shielding for Cables
madmat, Swomack and Banshee451 like this.
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #3 of 14 (permalink) Old 02-15-2017, 07:00 PM
Subscribing. I'm in the same boat bit I'm doing 12-14 still undecided.
I'm looking for a, black braided clutch and brake cables.
Is factory 47 wire kit no good?
Forgot to mention I'm a 2012 so maybe I should start my own thread?
Isaiah 43:2 “When you pass through the waters, I will be with you; and through the rivers, they shall not overwhelm you; when you walk through fire you shall not be burned, and the flame shall not consume you.”
buzzkill657 is offline
post #4 of 14 (permalink) Old 02-18-2017, 03:49 AM Thread Starter
Thanks for the input... Going with Namz and Magnum
Banshee451 likes this.
post #5 of 14 (permalink) Old 02-18-2017, 04:39 AM
madmat's Avatar
Originally Posted by Khaotic View Post
Namz for wiring
I went same route as Khaotic, great quality stuff and simple to work with.
18 RGS Bonneville Salt Pearl
madmat is online now
post #6 of 14 (permalink) Old 02-18-2017, 05:49 AM
Smarty's Avatar
That being said...
Ride safe...
Jason,
Honolulu, HI
On the wiring, the wire should come out of the bars with stock length. On the hydraulic lines it can be tougher. On mine, I was able to cut some ties and still make the lines work. It was tight but did work. The wires were a non issue though. Good luck.
bigqdiddy likes this.
2016 RGS Black Quartz
Smarty is offline
post #7 of 14 (permalink) Old 02-18-2017, 10:54 PM Thread Starter
Stock lines
Do you have a setup similar to mine? 16" apes? With factory brake and clutch lines? If it's possible to leave the hydraulic lines stock, that;s the route I want to take!
post #8 of 14 (permalink) Old 02-24-2017, 03:47 PM
Site Sponsor
factory47's Avatar
Hey Waikikijason did you ever do your install?
factory47 is offline
post #9 of 14 (permalink) Old 02-24-2017, 04:57 PM
Khaotic's Avatar
No way 16" without rewire and cables. maybe 14" on 2015+ . I used 6+ both break and clutch. I bought end to end on controls except TBW was long enough if I remember correctly. Talk to Factory47 and buy Namz and Magnum. Don't cheap out your life could depend on it.
Khaotic is offline
post #10 of 14 (permalink) Old 02-26-2017, 12:22 AM Thread Starter
No I have not... Probably will get it done next month. If it were a perfect world I would have your shop do the install. But I am in Honolulu and that's not an option.
Factory 47 10" Signature Bar for 2015-2018 Road Glide looneytune Parts for Sale 1 07-11-2018 11:39 PM
Looking to trade Brand new Factory 47 12" Signature bars for 10" version RedBlack Wanted! (Buy or Trade) 11 02-04-2018 10:31 AM
Factory 47 14" Signature Bars Gamedic10293 Controls & Handlebars 15 01-18-2018 12:23 PM
Factory 47 16" Signature Handlebars BigFatMike Parts for Sale 8 12-09-2017 09:00 AM
14" Factory 47 Chrome Signature bars for RG 2015-2017 Steveg Parts for Sale 9 01-30-2017 09:53 PM
