Replace riser bushings? - Road Glide Forums
 14Likes
post #1 of 50 (permalink) Old 02-25-2017, 12:21 PM Thread Starter
BB Bomber's Avatar
So I'll be replacing my bars soon. Was thinking of replacing the riser bushings since I'll already have things apart. Easy thing to do on a 15 RG?
BB Bomber is offline
post #2 of 50 (permalink) Old 02-25-2017, 12:35 PM
NorCal's Avatar
on my 16 RGS, when I changed my bars I also changed the bushings and it was a simple project. I went with the Arlen Ness Polyurethane Riser Bushing. Good luck.
RBouska likes this.
NorCal is offline
post #3 of 50 (permalink) Old 02-25-2017, 01:24 PM
speedkills66's Avatar
Yes easy enough on a 15 RG and in my opinion is something that should definitely be done.
madmat likes this.
2015 FLTRXS Road Glide Special
Jackpot 2-1-2 Header, Rinehart 4" Slip-Ons, HD SE Heavy Breather A/C, Road6 13" Standard Apes, PowerVision
115 TQ // 91 HP
speedkills66 is online now
post #4 of 50 (permalink) Old 02-25-2017, 07:39 PM
Bevis's Avatar
Just don't do like I did...My wife came out to chit chat and I put the bars on and forgot to do the bushings...even though I picked them up and moved them closer to the bike.
army12b and BB Bomber like this.
Bevis is offline
post #5 of 50 (permalink) Old 02-25-2017, 08:13 PM
BH#103's Avatar
I just did mine with the F47 bars I installed. Picked up the Drag Specialties poly bushings. The fit was pretty snug with the metal sleeve intalled in the bushings so I had to use a long bolt with nut and large washers to draw them together before the final assembly. Bars feel super solid now.
BH#103 is offline
post #6 of 50 (permalink) Old 03-03-2017, 07:24 PM Thread Starter
BB Bomber's Avatar
I can get the left side bottom bolt started easy enough, just not a lot of room to move. will have to pick up a long extension so I can get it tight enough.
My problem is getting the right one started ( have it out, can't seem to get it back in) with that mess of wires running along the frame. Any tips? I gave up for the night. Will take another go at it tomorrow.
post #7 of 50 (permalink) Old 03-03-2017, 09:04 PM
BH#103's Avatar
If you got the left side riser bolt in then just turn the handlebars left and use the fork lock to help keep the handlebars in place while you install that side. I used a torque wrench for the final tightening on mine and only had to use a short 3" extension. Did you get poly bushings installed?
BH#103 is offline
post #8 of 50 (permalink) Old 03-04-2017, 04:02 AM
RFG7680's Avatar
Use dawn dish soap.for the assembly. Everything will slide together nicely. If you dry fit everything it will be a struggle.
BlazingSaddle likes this.
RFG7680 is online now
post #9 of 50 (permalink) Old 03-04-2017, 07:08 AM
I replaced mine with arlen ness and grade 8, 2-1/4 bolts the factory bolt is a little short.
steve2100 is offline
post #10 of 50 (permalink) Old 03-04-2017, 08:41 AM Thread Starter
BB Bomber's Avatar
I went with the arlen ness polys.
Thanks for the tips. Going to try again this afternoon after work. This has turned into a task way harder than it should've. Murphy's Law is in effect. And not just with this bushing bolt problem.
Handlebar Vibration and Riser Bushings AAbiker Controls & Handlebars 0 06-17-2014 05:43 PM
Poly riser bushings matty3000 Controls & Handlebars 2 11-08-2012 07:57 PM
Polyurethane Handlebar Riser Bushings longrides Miscellaneous for Sale 0 09-16-2012 06:11 PM
Handlebar Riser Bushings for Apes? Tek74 Controls & Handlebars 3 02-24-2012 11:33 AM
Riser bushings? AZCFH Troubleshooting for Road Glides 4 01-22-2011 09:59 AM
