Installed bars now heated grips are inop - Road Glide Forums
  • 1 Post By doctor mike
post #1 of 9 (permalink) Old 02-27-2017, 05:04 PM Thread Starter
I installed my new bars over the weekend. Since then the heated grips don't work.
As near as I can tell the heated grips get their power from the two wire connector (female) with a purple and black wire.
Now here is where some of my confusion started. There is a two wire connector (male) with a red and black wire and also a two wire connector (male) with a white and black wire. Also one other two wire connector (female) white and black.
So my assumption was the black and white male and female connectors go together. The male red and black goes to the female purple and black. Can someone confirm if this is correct?
With that configuration I had no power. Double checked connections and found one of the wires in a black and white connector was broken. So I cut off the connectors on the male and female and spliced the wires together. Still no heated grips.
Using my power tester I confirmed with switch on there is power on the purple wire. When it is plugged into the red and black connector I then have power to the black wire no matter the position of the power adjustor on the left heated grip. Is this normal to see power on the black wire no matter the position of the switch?
I unspliced the wires and checked all the black and white wires and found power on the black wire coming from what I believe is the left handlebar. Again this is when I have the power switch to the bike on.
Any suggestions or comments? Does anyone have access to actual wiring diagram to confirm how things are to be wired up?
Bill
2015 Road Glide Ultra CVO
Vance & Hines Power Duals with CFR mufflers
05Quadrasteer is offline
post #2 of 9 (permalink) Old 02-28-2017, 07:47 PM
BH#103's Avatar
What year bike are you dealing with and were the heated grips installed previously or installed new with the new bars?
BH#103 is offline
post #3 of 9 (permalink) Old 02-28-2017, 08:53 PM
doctor mike's Avatar
did you look inside the right grip handle and reconnect the small 2 prong connector?and yes the black and white wires go together,they hook left grip to right grip.
RGKen likes this.
BBP ULTRA,14" FACTORY 47 BARS,DAY MAKERS,MEAN MUG,JACKPOT 2-1-2,V&H MONSTER OVALS,WOODS 222 CAMS,MACH2 AC,POWER VISION,500 WATT J&M ROKKER 6 SPEAKERS,AGITATOR RIMS
doctor mike is offline
post #4 of 9 (permalink) Old 03-01-2017, 05:12 AM Thread Starter
The bike is a 2015 Road Glide Ultra CVO. The heated grips were on the bike as stock equipment.
When you say inside the hand grip where exactly are you talking about? Inside the actual grip or inside the bars where the throttle control went?
If the storms are done by the time I get home tonight I will be double checking all the wiring to see if maybe there is another broken or loose wire.
Bill
post #5 of 9 (permalink) Old 03-01-2017, 11:42 AM
CR3999's Avatar
On the throttle side, there is a little plug that plugs into the end of the grip. I think that is what he's talking about.
Here is a write up I did on another site. The only problem is that you can not see the color of the wires in the last picture. If memory serves me right, the other plug had a purple wire in the plug.
http://www.hdforums.com/forum/milwau...on-17-rgs.html
17 Road Glide Special
CR3999 is offline
post #6 of 9 (permalink) Old 03-01-2017, 06:08 PM
its in the grip itself, end of the grip pops off.look down inside you'll see 2 wires hooked to a small plug.very thin pins on the end be careful.I bet there already bent just carefully bend then back up,take a pair of needle nose and plug them back into the throttle sensor.the cap when put back on will hold it in.mine didn't look like the one in the picture of previous post but same location.
post #7 of 9 (permalink) Old 03-02-2017, 06:24 PM Thread Starter
Thank you all. Found the connector you were referring to at the end of right grip today. Put it back in place and spliced together the wires that I initially broke and now all is good.
Bill
post #8 of 9 (permalink) Old 03-02-2017, 07:18 PM
BH#103's Avatar
Bill
Well done.
"SLIVER"
BH#103 is offline
post #9 of 9 (permalink) Old 03-02-2017, 08:28 PM
BlazingSaddle's Avatar
Bill
I always appreciate a follow-up, especially when there's a solution to the problem. Thanks!
BlazingSaddle is offline
Fuel gauge, air temp gauge inop Crcarnage87 Troubleshooting for Road Glides 1 04-17-2017 06:19 PM
Heated Grips Vs. Heated Gloves Big Spoon Aftermarket Accessories 24 12-26-2016 09:36 PM
Heated Gloves or Heated Grips BlackDangerous Clothing 50 05-02-2013 09:10 PM
Another 2004 Cruise Ctrl inop Gayton81 Troubleshooting for Road Glides 4 11-19-2011 03:58 PM
Heated Grips vs Heated Gloves? sojourner Aftermarket Accessories 10 06-09-2010 01:02 PM
