Ignition Switch Help in St. Louis - Road Glide Forums
post #1 of 9 (permalink) Old 03-01-2017, 10:26 AM Thread Starter
mmfinn's Avatar
My ignition switch popped out and I cannot get it back in. Does anyone in the St. Louis area have the ignition tool for lining up the slots?
mmfinn is offline
post #2 of 9 (permalink) Old 03-01-2017, 10:45 AM
Hdclw99's Avatar
You can use a medium screw driver. Also if they get out of alignment real bad, you can take the switch apart and align them. I did the same thing and had them twisted up real bad, Hope it helps,,
Hdclw99 is offline
post #3 of 9 (permalink) Old 03-01-2017, 11:06 AM
Root76's Avatar
Popped mine out, turned the bars and got it out of sync. Thought I'd have to buy the alignment tool but I kept messing with it and finally got it back in there. May have to turn the bars just right? Good luck.
Midnight Pearl 2013 CFR pipes Khrome Werks handelbars
Root76 is offline
post #4 of 9 (permalink) Old 03-01-2017, 11:13 AM
BH#103's Avatar
Don't worry about purchasing the tool. I messed mine up and thought about buying the alignment tool, but after having a stare down with the.switch I just disassembled it and realigned it. So much easier than you may think. Good luck!
BH#103 is offline
post #5 of 9 (permalink) Old 03-01-2017, 11:34 AM
Thermodyne's Avatar
I have the tool, but I think the screwdriver works better. The tool is mostly good for working the switch with the stem out.
With that said, that stem is a real piece of work, the MoCo should have redone that thing when they went to canbus.
Thermodyne is offline
post #6 of 9 (permalink) Old 03-01-2017, 12:53 PM
WTFranz's Avatar
Agreed!
Had Mine all twisted up! and so Frustrating!
Sleep on it, then strap on your LED head mounted light and grab a Med Screwdriver. Look down the hole and start twisting each layer till the slots all line up. Then insert the switch stem making sure the detente is retracted.
WTFranz is offline
post #7 of 9 (permalink) Old 03-01-2017, 04:01 PM
Wood's Avatar
That's what I did.
Wood is offline
post #8 of 9 (permalink) Old 03-13-2017, 11:39 AM Thread Starter
mmfinn's Avatar
Thanks for all the input. What I finally did was insert a flat tip screwdriver all the way down and turned it all the way left. Then I slowly pulled the screwdriver up to the next layer and turned it all the way to the left. Once I completed them all the ignition slipped right in and I am good to go.
mmfinn is offline
post #9 of 9 (permalink) Old 05-08-2018, 04:37 PM
is there a retainer of some sort that holds it in? mine has popped out 3 times. usually when i'm rushed and it's a PITA to get back together in the parking lot.
e.nigma is offline
St st st stages BigNorm Engine Related 5 02-29-2016 08:46 AM
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 07:18 AM
Wide open swap meet St. Louis Illiniroads General Off-Topic Discussions 2 02-11-2012 08:11 PM
St. Louis to Chaleston, SC & Back in 4 days! maddogcapt Road Trip Discussions/Stories/Pictures 1 11-02-2011 07:50 AM
New RGU Owner from St. Louis maddogcapt New Members Welcome Area 20 10-02-2011 09:12 PM
