Road 6 13" apes on 2017 RGS? - Road Glide Forums
 2Likes
post #1 of 14 (permalink) Old 03-22-2017, 11:48 PM Thread Starter
I just traded my 2016 Road Glide for a 2017 Road Glide Special. I took a demo at Bike Week and just had to do it!
I have seen some conflicting information on this. I saw a few posts from about a year ago where people were able to swap 13" and 14" bars onto a 2017 without cable extensions. But the dealer told me HD uses a new supplier for cables on the newer bikes so I can't fit more than a 9" ape on the new bike.
Can anyone confirm either way so I can order another set of Road 6 13" bars! I really miss the apes!
JustinC13A is offline
post #2 of 14 (permalink) Old 03-23-2017, 12:00 AM
All I have to say is dealers lie a lot. I only went with 10" rise on my 17, but I could see easily going with 13 or 14, there's plenty of wire left. You may have to rearrange your clutch and brake cables, but there is slack there also.
post #3 of 14 (permalink) Old 03-29-2017, 08:45 PM Thread Starter
I went ahead and bought the 13" bars and they seem to fit!
Problem is I was a little hasty taking the stock bars off and I ended up with one wire coming off the throttle side that I cannot find a partner for. It has one black wire and one white wire on it.
There is another unused connection behind the speedometer with one purple wire and one black wire, but there is a cap on it. If I remove the cap, the wire will connect. The problem is I did not put the cap on so it doesn't make sense.
Anyone have an idea on where I went wrong?
post #4 of 14 (permalink) Old 03-29-2017, 09:02 PM
Tin Man's Avatar
I have done bars on a few 09-13 RG's and from memory I think there was an extra wire on the throttle side that was pre-wired for handwarmer or something. I don't have my drawings or shop manual handy right now though. I do remember just cutting off an extra wire to make the wire bundle easier to wire internally in my apes. I will look at my diagram when I get home, bit hopefully an expert will chime in first.
JustinC13A likes this.
Tin Man is offline
post #5 of 14 (permalink) Old 03-29-2017, 09:04 PM Thread Starter
I was thinking that might be an option. It just confused me that the white and black wire is part of the bundle of wires coming from the throttle. It makes sense for the one behind the speedometer.
post #6 of 14 (permalink) Old 03-29-2017, 09:08 PM
Tin Man's Avatar
Yeah. I have no clue about the one behind the cluster. Wish I could be more help.
Tin Man is offline
post #7 of 14 (permalink) Old 03-29-2017, 10:32 PM
Road Glide 2's Avatar
The wires you are seeing is for heated grips, one for throttle by wire grip side and the other is left grip..
https://www.youtube.com/watch?v=E94qcAJr4Jk
Road Glide 2 is offline
post #8 of 14 (permalink) Old 03-29-2017, 10:38 PM
The wires you are seeing is for heated grips, one for throttle by wire grip side and the other is left grip. The you tube explains what the wires are for, hope this helps..
post #9 of 14 (permalink) Old 03-29-2017, 10:38 PM Thread Starter
I put it back together and everything works so it's all good!
Now the check engine light is on though, I can't catch a break with this stuff!
Thanks for the input!
post #10 of 14 (permalink) Old 03-30-2017, 07:27 AM
Tin Man's Avatar
The throttle by wire connector is very fragile. Not sure if it would throw a code, but maybe. I ended up cutting out the connector and soldering it together.
Did you wires the bars internally or externally?
Tin Man is offline
[FS] Road 6 Customs Standard Apes 13" - $130 shipped wevsspot Parts for Sale 7 04-30-2018 07:38 PM
Klock Werks 14" Sport Flare Windshield - 2015 - 2017 Road Glide - EXCELLENT "USED" CO 2WHEELFREAK Parts for Sale 1 02-04-2017 09:46 PM
2016 RGS or 2017 RGS? PEZRACER *General Road Glide Discussions/Pictures 11 09-01-2016 02:14 PM
Road 6 13" Apes Installed. 15 Mr.Mike Controls & Handlebars 11 01-10-2016 09:00 AM
