16"-18" Apes, extension lenths???? - Road Glide Forums
post #1 of 11 (permalink) Old 11-14-2010, 09:00 AM Thread Starter
Question 16"-18" Apes, extension lenths????
New to forum and baggers, first time ever doin apes. I am 6'2" and looking for a comfortable height, also going to be getting a tallboy seat or one of that nature for more leg room, I was thinking 16 or 18's. I read the other posting about the extra wire lenght in the fairing, but what size extension did anyone else run or should you run on 16/18. Also I dont have ABS did need to do anything different? The way it sounds I need wire extension, clutch and thats it?????? Tahnx for everyone's help.
tiko_joe is offline
post #2 of 11 (permalink) Old 11-14-2010, 10:26 AM
Neano62's Avatar
pm Chainsaw. He is the Ape Ruler! lol
[/IMG]
Neano62 is offline
post #3 of 11 (permalink) Old 11-14-2010, 12:15 PM
molitord's Avatar
I have 10" Yaffe apes, as doesn Neano, I believe. No extensions on the wiring on those so, you should be able to add 8-10" extensions for 16-18" apes. My advice is get more than you need. You can always zip tie the extra wire in the fairing. Standard Clutch and brake cables also work with 10" Yaffe bars but I am going to extend the clutch cable by 2" when I change to braided cables so, you will probably need 8" or so on your clutch cable. The brake line has plenty of length using standard so I wouldn't have much input there. I'm not sure what type of apes you are wanting to run but there is a company called Hill Country Customs in Austin, Texas [URL="http://www.hillcountrycustomcycles.com"] that will send you the bars pre-wired. Takes all the guess work out.
molitord is offline
post #4 of 11 (permalink) Old 11-14-2010, 06:06 PM
CHAINSAW's Avatar
Depending on what year bike will determine if you need extensions on the wiring. On the 2010 and up, you have enough wiring under your fairing to do 24" bars. Clutch cable and brake line are the things you will have to get longer of. If you have TBW, there is enough for up to 20" bars under the fairing as well.
Such is the rule of honor.
CHAINSAW is offline
post #5 of 11 (permalink) Old 11-21-2010, 07:44 AM Thread Starter
its a 2008 and TBW, so then I am looking at +6 to +8 on the clutch and brake, with no wire extensions?
tiko_joe is offline
post #6 of 11 (permalink) Old 11-21-2010, 10:32 AM
edsglide's Avatar
Chainsaw do yaffe 10's need extensions or not ? Christmas is around the corner.
edsglide is offline
post #7 of 11 (permalink) Old 11-21-2010, 05:18 PM
CHAINSAW's Avatar
Yes sir
You need nothing, stock cables works with the 10" yaffe's.
CHAINSAW is offline
post #8 of 11 (permalink) Old 11-21-2010, 05:41 PM
edsglide's Avatar
Cool It's a 09 with a b s /cruise
edsglide is offline
post #9 of 11 (permalink) Old 11-21-2010, 06:52 PM
MassHD's Avatar
Mine too Ed. I just odered the cruise, one piece tbw, PM grips from HD dealer up the street. Going to do the bars right after T day. Hey do I new a HD dealer flash for the cruise to work?
2010 Road Glide Denim Black
ABS Cruise Factory Security, Black D&D 2 into 1
Firecap's Arc Amp 125.2, 4- Hertz 6 1/2" Speakers
PYO Bars, CVO Rear Fender, KW Wrapper Front Fender
"Burn Rubber Not Your Soul"
MassHD is offline
post #10 of 11 (permalink) Old 11-24-2010, 06:24 AM
Peewee's Avatar
Hey Chain, I'm looking at putting 12" apes from KhromeWerks on this weekend. I got a 2010 FLTRX w/ABS. Think the stock cables will work?
Peewee is offline
16" HD apes for '16 CVO Road Glide Sharkbreath Parts for Sale 1 03-21-2017 02:27 PM
16 FLTRX wanting 16" apes! VTdenimRG Controls & Handlebars 9 09-16-2016 07:24 AM
Harley brand apes for 16-16 -looking for pat numbers for extended wires/lines Steelerdude1 *General Road Glide Discussions/Pictures 2 10-17-2015 08:41 PM
stock 16" shield hits new 14" apes 2" shy of fork stops. Will a Mako fit? chevjerico Windshields 0 12-04-2013 11:02 AM
18" or 20" apes - need cable length CHAINSAW Controls & Handlebars 2 10-23-2010 11:39 PM
