Running brake/clutch lines - Road Glide Forums
post #1 of 3 (permalink) Old 04-28-2017, 09:07 PM Thread Starter
In the process of installing my 14" Factory 47 bars.....everything is pretty much done but the brake and clutch lines seem pretty tight.....trying to put the gauge cluster back in.....y'all have any insight on how I can get these lines out of the way?
Also....check engine is on when I started it.....I'll deal with that when I get this issue resolved. (I did turn on the ignition with the cluster out.....ooops)
Disregard.......I think I got it.
Rgguy is offline
post #2 of 3 (permalink) Old 04-28-2017, 09:30 PM
BH#103's Avatar
Route the brake and clutch lines so they come out in the forward gap that is between the gauge nacelle and the handlebars to the left and right of the riser clamps, cut any zip ties that are encouraging the lines to not conform to how you need them and you should be able to gain some extra slack too. If your bike is a '15, that check engine light could be lit from the tbw connector coming undone inside the bars. Don't ask how I know of this!
BH#103 is offline
post #3 of 3 (permalink) Old 04-28-2017, 09:31 PM Thread Starter
Thank you.....I ended up just taking the housing of and was able to route them better.......thanks.......I'll probably be posting later about the tbw
Rgguy is offline
Clutch and brake lines for 16 inch bars on a 2015 Road Glide daryl_db Controls & Handlebars 2 03-20-2015 08:16 AM
Braided Stainless Brake Lines and clutch mrmoto95 Parts for Sale 0 07-26-2014 07:30 PM
Extended brake and clutch lines for WO502 Ezgravy Controls & Handlebars 12 04-13-2013 04:38 PM
SS Clutch and Front Brake lines Robare Controls & Handlebars 9 04-11-2013 04:53 PM
Brake and clutch lines fosterp Controls & Handlebars 2 01-06-2012 08:03 AM
