Ape Hanger Survey - Your Height & Bar Height - Road Glide Forums
 8Likes
post #1 of 55 (permalink) Old 05-02-2017, 09:39 AM Thread Starter
JDisMe's Avatar
I see it mixed in through a lot of the posts here, so how about a comprehensive list? I'm in the market for bars and I know those of you that have/had apes went through the trouble of figuring out which height to get.
So how about including:
Your Height -
What height bar you went with. (If tried multiple heights, which ones you started with then what you settled on.) -
Which brand of bar you went with -
Did you use stock cables? - Y/N
What year RG? -
Did you swap riser bushing? Y/N
Different seat?
Ride safe!
--2019 RGS--
--2012 Road Glide Custom--Gone But Not Forotten
JDisMe is offline
post #2 of 55 (permalink) Old 05-02-2017, 09:47 AM
I think unless you are really short or really tall it is just a preference.
Your Height - 6'3"
What height bar you went with - 13" on a 2016 and a 2017 Road Glide
Which brand of bar you went with - Road 6 Customs (twice, they are good and very well priced)
Did you use stock cables? - Yes
Did you swap riser bushing? No first time, Yes second time. I recommend doing it while the bars are already off.
JustinC13A is offline
post #3 of 55 (permalink) Old 05-02-2017, 09:48 AM
I'll volunteer,
5'8" 200lbs 32" inseam, don't know my arm length
I have 10" Appleton Customs now, very comfortable, set me up straight, but I do a lot of slow speed maneuvers (practicing) and my arms tend to get a little tired quickly.
I'm going to be putting 14" on soon, will update.
PS, no cable or wire changes with 10's, plenty slack left.
post #4 of 55 (permalink) Old 05-02-2017, 09:53 AM
Momania's Avatar
Your Height - 6'-0"
What height bar you went with. (If tried multiple heights, which ones you started with then what you settled on.) - 12"
Which brand of bar you went with -Todd's Cycle
Momania is offline
post #5 of 55 (permalink) Old 05-02-2017, 09:57 AM
bless0's Avatar
Your Height - 6'1"
What height bar you went with. 12"
Which brand of bar you went with -Bad Seed Cycles $235 shipped
Did you use stock cables? - YES
Did you swap riser bushing?No but eventually will since taking the bars off is super easy.
johnnynitro likes this.
bless0 is offline
post #6 of 55 (permalink) Old 05-02-2017, 10:03 AM
HarleyArcher's Avatar
6'3"
12" KST bars
Everything else OEM stock.
Currently bikeless but sticking around for knowledge.
HarleyArcher is offline
post #7 of 55 (permalink) Old 05-02-2017, 10:04 AM
MisterUSA's Avatar
Height-6'2"
16" on my 2005 Road King back in the day (custom engraved eBay purchase)
19" on my 2008 Electra Glide (a little tricky at slow speed turns/maneuvering in a parking lot)
16" on my current 2013 Street Glide (1 1/2" dia. Stepped down at the grips and steering column mounting)
Magnum Shielding Black Pearl wiring extension kit.
Stock mounting at the yoke.
MisterUSA is offline
post #8 of 55 (permalink) Old 05-02-2017, 11:23 AM
Height 6'
bars=Yaffee's 16"
used stock cables
no on bushings (I forgot to order them didn't want to wait)
Big Mac
racing724 is offline
post #9 of 55 (permalink) Old 05-02-2017, 11:28 AM
direwolf's Avatar
Your Height - 6' 3"
What height bar you went with. (If tried multiple heights, which ones you started with then what you settled on.) - 16" on both roadies, tried the Heritage bars from HD on the 08 b4 I purchased the 16's. Took one 800 mile trip and ordered the 16's, I felt they were worse than the stock for me.
Which brand of bar you went with - LA Choppers on both, 08 has Blk Powdercoated Apes, 09 has Chrome Twin Peaks style
Did you use stock cables? - Y/N No
Did you swap riser bushing? Y/N Yes just to be on safe side
2008 FLTR & @009 FLTRSE3
HD Road Zeppelin (with Compressor) Seats on both.
...2009 SERG...Last of the Hand Built's..
direwolf is offline
post #10 of 55 (permalink) Old 05-02-2017, 11:35 AM
michaelgrudgings's Avatar
Bars
6'4
Factory 47 14 inch bars
Installed when I bought it no idea on cables and riser.
2015 RG Factory 47 14 inch apes, SE Heavy Breather, D&D Boss Fat Cat ...............
michaelgrudgings is offline
Ape hanger height and your height? Busted1 Controls & Handlebars 196 01-21-2018 01:57 AM
ape height and body height barbell01 Controls & Handlebars 22 03-28-2012 09:35 PM
