how high can i go on stock cables - Road Glide Forums
  • 1 Post By 08Zinc
post #1 of 6 (permalink) Old 05-03-2017, 01:22 PM
Ln Vintage
Guest
Posts: n/a
id like to go higher of course im tall , coming from 16" apes on my Indian , the stock bars aint cutting it, so with that said , without buying a whole new set of cables (i can do that at a later time) , how much higher can i go? If i could go 5 inches that would be awesome , just saying?
post #2 of 6 (permalink) Old 05-03-2017, 01:33 PM
08Zinc's Avatar
13-14" apes with factory wires Stock rise is 8 or 8.5", so 5" higher is doable. I have 13" Road 6 Custom Holey Rollers on mine.
Ln Vintage likes this.
Blessings, Zinc -
08Zinc is offline
post #3 of 6 (permalink) Old 05-03-2017, 04:07 PM
Ln Vintage
Guest
Posts: n/a
13-14" would be awesome!!!
post #4 of 6 (permalink) Old 05-03-2017, 04:48 PM
I think if you have abs you can go 13"-14". If no abs , 12 " is about it for the brake line but there's extra on everything else.
post #5 of 6 (permalink) Old 05-03-2017, 05:04 PM
HellInABucket's Avatar
The better question is, why would you want to potentially sacrifice comfort for the sake of keeping the hideous stock cables?
Pick the most comfortable bars and buy what's needed to make it work.
Stretching stock cables to get what may likely be shorter bars than would be most comfortable is a bad idea.
And even if you could get taller bars by force fitting stock cables you're still running stretched cables. Less than optimal.
2018 FLTRU
Roll away the dew...
HellInABucket is offline
post #6 of 6 (permalink) Old 05-04-2017, 05:29 AM
psrumors's Avatar
When I installed 12" KSTs on my '16 RGS the brake and clutch line was tight, I could not imagine getting 14" on. I'll be going to 14" but will be replacing the lines. Wiring is no problem
'17 Road Glide Ultra - Fuel Moto 2-1-2 header, RC Components 4" Slipons
psrumors is offline
Some go Black Some go Chrome I go my way BACA POPEYE *General Road Glide Discussions/Pictures 66 06-21-2019 09:58 AM
How high can you go before changing NS RoadRunner Controls & Handlebars 9 01-16-2014 01:42 PM
Can you use your stock cables with 13" apes Tgrant1024 Controls & Handlebars 4 02-17-2013 07:19 PM
How High Can I Go Skitzogear Controls & Handlebars 18 12-07-2012 11:48 AM
