16" Apes - Road Glide Forums
post #1 of 3 (permalink) Old 05-27-2017, 12:34 PM Thread Starter
16" Apes
I'm installing 16" LA Choppers apes onto my 2016 FLTRXS and I need a reality check. Do I have everything that I'll need listed below?
Hyd clutch line
ABS mid-line brake line
ABS Lower & Upper brake line
Copper Crush Washers
T.B.W. harness extension
Controls harness extension
I can easily find places for the cabling but where would you all recommend for a hose kit?
CombatVetRob is offline
post #2 of 3 (permalink) Old 05-27-2017, 02:31 PM
Silence's Avatar
Not 100% sure but from reading all these threads it seems like anything pass 14" you must change out all cables/wiring on the 2015+ models. This is a very common question so search the threads and im sure it'll be answered.
Silence is offline
post #3 of 3 (permalink) Old 05-27-2017, 03:17 PM
BH#103's Avatar
Hyd clutch line
I will be doing this same job for a buddy on his '09. He wants 16" LA chops installed. You don't want to forget your fluids and poly bushings for the lower clamps. I'd recommend the Drag Specialties ones from eBay. I personally install the Harley lower clamp bolts that they sell with their poly kits on all the bar installs I have done using poly. The electrical I source from Namz and for this job he got the 1 and done kit that Magnum sells for his '09. Good luck! Hope this helps a little.
BH#103 is offline
16" HD apes for '16 CVO Road Glide Sharkbreath Parts for Sale 1 03-21-2017 02:27 PM
16 FLTRX wanting 16" apes! VTdenimRG Controls & Handlebars 9 09-16-2016 07:24 AM
Harley brand apes for 16-16 -looking for pat numbers for extended wires/lines Steelerdude1 *General Road Glide Discussions/Pictures 2 10-17-2015 08:41 PM
stock 16" shield hits new 14" apes 2" shy of fork stops. Will a Mako fit? chevjerico Windshields 0 12-04-2013 11:02 AM
