Bike is down and need cables - Road Glide Forums
post #1 of 8 (permalink) Old 06-22-2017, 11:26 AM Thread Starter
wpsharpshooter's Avatar
Well Im looking for some cables. I need the lower/upper brake and clutch in stainless for my 17 RGS with 16in bars. I went with a complete kit from LA choppers and it was total garbage, Wrong lengths and the fittings had funky angles putting my cables way out from the bars. Now Ive got my bike tore down and need parts. Anybody have a line on these cables that are in stock?
2017 Laguna Orange Road Glide Special
16in Apes, Diamond Audio Micro 2, Arc Moto 602's, Full Stage 1, Chrome Front End
wpsharpshooter is offline
post #2 of 8 (permalink) Old 06-22-2017, 11:37 AM
JDisMe's Avatar
Check out www.magnumshielding.com
Sent from my SM-N920V using Tapatalk
--2019 RGS--
--2012 Road Glide Custom--Gone But Not Forotten
JDisMe is offline
post #3 of 8 (permalink) Old 06-22-2017, 11:46 AM Thread Starter
Im not sure what part numbers I am needing and Ive sent them an email and messaged them on FB with no asnwer back as of yet.
post #4 of 8 (permalink) Old 06-22-2017, 11:51 AM
I'd give them a call (877) 564-8248 they were very helpful when I ordered mine.
Big Mac
racing724 is offline
post #5 of 8 (permalink) Old 06-22-2017, 12:04 PM
wevsspot's Avatar
If you are going stainless, here are the part numbers;
ABS Dual Disc Designer Lower Brake Assembly
AS57016
ABS Dual Disc Mid-Line Brake Lines
AS57015
ABS Designer Upper Brake Lines
I'm assuming this is where the real question comes in as you are actually buying by the length and in your situation it is the length between the ABS module and the master cylinder on the bars. You can either wait for a call back or take a piece of string and run it between the fitting on the ABS module and the fitting on the master cylinder. Make sure your measurement string follows the contour of existing plumbing. Then measure the length of string for an exact fit. Remember to leave some play at the master cylinder so there isn't any potential for binding lock to lock and that the resulting contour of the new lines is pretty to your eyes
Changing out the lower brake lines is optional and only necessary of you are going for the "look" Otherwise you could just use your stock lower brake lines and save a good chunk of change. The mid and upper brake lines are mandatory as they are required to make the connection between the ABS module and master cylinder.
Hydraulic Clutch Line
I'd go at least +6 on the clutch line. The stock clutch line is 74" long.
So if you go +6
51880
wevsspot is offline
post #6 of 8 (permalink) Old 06-22-2017, 01:25 PM Thread Starter
I called them, talked to a lady named Sue, Super helpful. She gave me the drag specialty numbers as well so I could have my buddy order them at his cost. Here are the part numbers she gave me just in-case anybody else runs into my issue. Im running 16in bars and the brake line they only offer 7 or 9in so I opted for the 9in Also these numbers are for the Sterling Chromite II finish
Magnum P/N#
Clutch +8 31982
ABS Lower AS37016
Midline AS37015
Upper Brake +9 AS37224
DRAG P/N#
Clutch +8 1132-1064
ABS Lower 1741-4006
Midline 1741-4005
Upper Brake +9 1741-4033
post #7 of 8 (permalink) Old 06-22-2017, 01:42 PM
JDisMe's Avatar
Very cool. Glad you got it figured out.
Let us know how it all turns out when you're finished.
--2019 RGS--
JDisMe is offline
post #8 of 8 (permalink) Old 06-22-2017, 02:55 PM Thread Starter
Ill be so glad to wrap this up and get my bike on the road again. Between waiting on parts and my schedule. The bike will have been down for 2 weeks as of tomorrow. Now I have to wait on new cables so hopefully Ill get them next week. Good thing its supposed to rain all weekend.
Need extended cables, where do I get them from? ksarauer *General Road Glide Discussions/Pictures 6 06-17-2013 07:50 PM
where to get santee 14" and cables,best $$$?? dirtracer27x Controls & Handlebars 0 02-28-2012 11:17 PM
Cables and Brake Lines BigDum Controls & Handlebars 5 02-14-2012 11:24 PM
Need cables and lines!! bigcharlie *General Road Glide Discussions/Pictures 4 02-07-2012 08:25 PM
14" Bars and Cables lowglidin Controls & Handlebars 4 11-07-2010 12:39 PM
