Vindikta Marauder 12" on pre 2015 Glide - Road Glide Forums
  • 1 Post By Serenity
post #1 of 7 (permalink) Old 06-28-2017, 02:10 AM Thread Starter
hd4cruzin's Avatar
Has any one installed the Vindikta Marauder 12" bars on a Pre 2015? If so, were you able to use stock wires and brake and clutch cables?
Bill
2012 FLTRX BBP
hd4cruzin is offline
post #2 of 7 (permalink) Old 06-28-2017, 10:10 AM
Serenity's Avatar
those are real similar to the outlaws I just installed this past weekend. I was able to use stock cables but had to extend the electric wires
2013 RGC, DNA's, SE Chiseled Air Intake, Power Pro Black, 12" KST Outlaws, Memphis Shade Spoiler 5.5, Streamlined
Serenity is offline
post #3 of 7 (permalink) Old 06-28-2017, 10:59 AM Thread Starter
hd4cruzin's Avatar
How long did you have to extend the wires?
2012 FLTRX BBP
post #4 of 7 (permalink) Old 06-28-2017, 01:15 PM
RGKen's Avatar
I installed 13" Marauders on my 2012 FLTRXSE and I didn't have to extend anything. Although my hydraulic clutch line is a little tight and I do plane to put new lines on. I believe your cable clutch is a little longer or you can re-route it if needed.
2018 FLTRXS
RGKen is offline
post #5 of 7 (permalink) Old 06-28-2017, 02:54 PM
Serenity's Avatar
I had a shop do it as I watched. Serenity Cycles Extended both sides about 6" to allow for wiggle room. connectors were cut and soldered. No connectors are in the bars. It is all in the fairing. We re routed the braked and clutch cable to run inside the plastic shroud around the forks rather than out and that gave me plenty
hd4cruzin likes this.
Serenity is offline
post #6 of 7 (permalink) Old 09-15-2017, 10:52 AM Thread Starter
hd4cruzin's Avatar
Thanks for the info. I'll order wire extension kit from Namz
2012 FLTRX BBP
post #7 of 7 (permalink) Old 09-15-2017, 11:09 AM
Swomack's Avatar
Bill
All stock should work fine if their only 12" apes.
Swomack
My Gallery / Click Below Link
Swomack is offline
12" Vindikta Denaros on 2015 RGS with Pictures HighwayStar Controls & Handlebars 13 08-10-2016 03:22 PM
It is now 12:12 12-12-12!!! Garemlin General Off-Topic Discussions 10 12-12-2012 09:45 PM
Top Gear - The Marauder - BBC DreamRider General Off-Topic Discussions 8 10-09-2011 09:28 PM
