MoCoHeated Grips with Factory 47 - Road Glide Forums
 2Likes
post #1 of 14 (permalink) Old 07-06-2017, 04:25 PM Thread Starter
rider17's Avatar
So, all the MoCo bars say they won't work with heated grips. Local Dealer Chrome Consultant tells me they have a trick and it's a non issue. Anyone running MoCo heated grips on their 14" Factory 47 bars? Did you do the instal yourself?
rider17 is offline
post #2 of 14 (permalink) Old 07-06-2017, 09:14 PM
bosshogg123's Avatar
I put a set of MoCo Slipstream heated grips on my Kliphangers. I ended up sending them to Jennifer at KlockWerks to run my wires (pre-Rushmore, a real PITA), so I had her install them. She ran the power lead inside the bars, they work great!!
bosshogg123 is offline
post #3 of 14 (permalink) Old 07-07-2017, 07:53 AM
BH#103's Avatar
I just installed some LA Choppers 16" apes on a '09 CVO and the owner wanted heated grips. The CVO came with them, but they worked half ass so I told him to pick up some new ones. He got some brand new model, Slipstream I think. The first 2 sets he got the left grip was defective right out of the box. The 3rd set was an older model and worked perfect. They make the grips so the power cables run external and the grip to grip connection is internal. If you go about it the right way it can all be internal. There are some good vids on YouTube showing the process. Good luck!
BH#103 is offline
post #4 of 14 (permalink) Old 07-07-2017, 09:07 AM
I had the dealer install the low Z handlebars on the bike with heated handgrips. They just had to bore out slightly the bars. Not a big deal and they work great in the late fall/early winter!
US ARMY 1975-1985 IBA 69057 2017 RGS; 107; Stage I; Low Z chizeled handlebars; chopped engine guard; SE Mufflers; LED Cluster lights; Clearview Windshield; heated grips; lighted switches; Custom seat from Mean City Cycles.
2016CTRoadGlide is offline
post #5 of 14 (permalink) Old 07-14-2017, 11:15 PM Thread Starter
rider17's Avatar
So what did they charge you? I was in getting my belated 1k service and some warranty work done. Asked the service department about cost and they said it would be a 9 hour job. Of course I see you went with the low bars. I was asking about 14" and you would've thought I'd ask if they could make my bike a gold wing.
rider17 is offline
post #6 of 14 (permalink) Old 07-15-2017, 06:11 AM
lastride's Avatar
I did my F47 12 inch bars with the Harley heated grips. Did my buddy's F47 14 inch bars on his street glide with heated grips. You just need to grind a small notch in the end of the grip so the wire can sneak by without getting pinched.
rider17 likes this.
lastride is offline
post #7 of 14 (permalink) Old 07-15-2017, 08:46 AM Thread Starter
rider17's Avatar
Were the grip wires long enough or did you have to splice them?
rider17 is offline
post #8 of 14 (permalink) Old 07-15-2017, 09:03 PM
Jersey Drew's Avatar
was this on a rushmore bike? or 13 and older
'16 Road Glide Special
Jersey Drew is offline
post #9 of 14 (permalink) Old 07-17-2017, 09:09 AM
lastride's Avatar
Wires were long enough, bikes were 2015.
rider17 likes this.
lastride is offline
post #10 of 14 (permalink) Old 07-17-2017, 09:20 AM
Ln Vintage
Guest
Posts: n/a
9 hour job!!! What were they gonna do fly to los angeles for lunch , then fly back and install the lines? theres only two more cables that need to be sent through internally and then plugged in , this isnt rocket science!
Just ordered my new 2015 factory 47 (formerly Buky Bars) road glide bars Wotsrab Controls & Handlebars 33 05-03-2016 10:04 PM
Factory 47 malo 16 inch rise with heated grips bigmatt1967 *General Road Glide Discussions/Pictures 3 12-27-2015 08:53 AM
Factory 47 / Buky Bars cruznmarine Controls & Handlebars 37 04-26-2015 11:54 PM
Road glide hand guards on 14 inch Buky bars ( factory 47 ) opinions? ccsolo24lal Controls & Handlebars 33 03-15-2015 11:32 AM
Factory 47 rg113 Controls & Handlebars 22 02-07-2015 10:25 AM
