2011 CVO handlebars on an 09 - Road Glide Forums
post #1 of 17 (permalink) Old 11-21-2010, 08:55 PM Thread Starter
sh4325's Avatar
Thumbs up 2011 CVO handlebars on an 09
I just finished installing the 2011 CVO Handlebars on my 09. These bars are much better than the stock ones. PITA to get on though but I did it. They actually do not work with the 09 but I made them fit. I thought that they were interchangeable but I was wrong but I am glad that I got them on. Taller and they pull back a lot more than the standard 2009 bars. I love these bars! All of the wiring and cables were long enough. If anyone wants to do this I can walk them through. As always I could have done a better job if I had it to do over again.
sh4325 is offline
post #2 of 17 (permalink) Old 11-21-2010, 09:13 PM
FLTRI's Avatar
What made them hard to install?
I hate that motorcycle they make me ride. I'm here to tell you there ain't nothing in the world I hate worse than that elephant under my ass.
Officer John Wintergreen reference his Electra Glide.
-Electra Glide in Blue, 1973-
FLTRI is offline
post #3 of 17 (permalink) Old 11-21-2010, 10:00 PM
Deuce Bigelow's Avatar
before and after pics?????
2010 FLTRX
Deuce Bigelow is offline
post #4 of 17 (permalink) Old 11-21-2010, 11:20 PM Thread Starter
sh4325's Avatar
Thumbs up
The wiring was the hard part. The bars will fit with no problem. The original handlebars have a pressed indentation on the bottom of the bars at each end. This indentation at each side of the bar allows some space to get the wiring cable to fit into the two halves of each control piece with out damaging the wiring when you try to install the clutch and front brake lever pieces. The wiring will get pinched when you try to tighten the control pieces with out this space. The CVO bars are made for all of the wiring to be installed inside of the bars and they do not have this indentation stamped into the underside of the bars. So I had to create some room to prevent damage to the wiring where they exit each control piece. I took a sharpie pen and marked the same shape of the indentation on the stock bars on to the CVO bars. I took my dremel tool with a metal cut off blade and cut a rectangle slot into the CVO bars. The Dremel tool worked like a champ! There is an elongated hole already in each end of the CVO bars. So I started my cut there. It's hard to verbally explain this so I hope that I am getting the message across. I also had to drill two holes in each bar for the clips that hold the wring to the bars since I could not run all of the wiring inside of the bars. I could run the fly-by-wire wiring into the right side bar but there is an additional wiring harness that cannot be run inside of the handlebars. Also on the left bar the wring cannot be installed inside of the bars. The wiring harness on the left side will not fit inside of the CVO bars. The connector at the end of the harness is to big to fit inside of the bars. Same on the right. So......the wiring harness on the 2011 CVO Road Glide has to have a different wiring harness for the left and right side controls. They would have to have a means of disconnecting the harness and be able to reconnect it like the fly-by-wire throttle wiring. Another plus is my mirrors are higher up now so I get a much better view now. Any way it was much more work than I anticipated but was well worth the result. I highly recommend these handle bars.
sh4325 is offline
post #5 of 17 (permalink) Old 11-22-2010, 04:59 AM
Do you have a part # for the cvo bars?Im lookig to put some on mine.
Thanks
harley99 is offline
post #6 of 17 (permalink) Old 11-22-2010, 07:17 AM
sh4325,
CVO bikes do not have a different harness for the switch controls.
when they wire the handlebars at the factory, they run the wires through the bars before they put the connector on the end.
to run your wires internally, you would either have to take the connector for each switch assembly apart, or cut and splice the harness back together.
it's a pain in the ass to do, but the results are worth it!
2010 FLTRX
post #7 of 17 (permalink) Old 11-22-2010, 07:46 AM
Bluzmn59's Avatar
I ordered a set of these for my 2011 FLTRU and they just came in. I will be getting them installed next week and I can't wait to lose the stock drag bars (well, that's what they feel like anyway).
Life is hard. It's really hard if you're stupid.
1959 FLHF
2007 FLSTSC
2011 FLTRU
Bluzmn59 is offline
post #8 of 17 (permalink) Old 11-22-2010, 07:57 AM Thread Starter
sh4325's Avatar
You are exactly right. The stockers are like drag bars. With the CVO bars on my bike feels like a completely different ride! One of the best changes that I have made.
sh4325 is offline
post #9 of 17 (permalink) Old 11-22-2010, 07:58 AM Thread Starter
sh4325's Avatar
Thanks
Part number is 57461-11.
sh4325 is offline
post #10 of 17 (permalink) Old 11-22-2010, 08:03 AM Thread Starter
sh4325's Avatar
Originally Posted by Deuce Bigelow View Post
sh4325,
Maybe I will change it out sometime. I thought about cutting all of the wires but I didn't want to jack with it at the time. I have been working on my bike so much is the last few weeks I was getting tired of working on the damn thing and wanted to ride. Every time I take the fairing off it's a PITA to get the outer fairing back on!
sh4325 is offline
New RG CVO handlebars for 2011 Ultra marcesmith Controls & Handlebars 3 08-17-2015 07:04 PM
09+ Tour Pak Mount (53411-09) and Side Covers (L-47526-09, R-47522-09) bikerglasses Parts for Sale 3 12-06-2013 09:33 AM
throttle cable handlebars and tbw handlebars Swagzilla Controls & Handlebars 2 01-30-2012 07:30 PM
2011 CVO RG has newly designed handlebars DED HD Controls & Handlebars 2 08-16-2010 03:54 PM
HD Handlebars 56166-08 for 09 RG HDKid Controls & Handlebars 0 04-27-2010 09:05 PM
