Ignition Switch "Ping" - Road Glide Forums
 3Likes
post #1 of 11 (permalink) Old 07-11-2017, 06:15 PM Thread Starter
JDisMe's Avatar
So I mentioned this in my other post about doing my bars and I've gone out and toyed with it and I can't get it to go away, so I'm reaching out to the brilliant minds on this forum.
I put the ignition switch back in and everything works, BUT when I turn it all the way counterclockwise, just before it gets to "Fork Lock" it makes a loud Ping sound. It still locks the forks, but that sound is irking me!
I've pulled it out and re inserted it a few times and it still does it.....any ideas??
--2019 RGS--
--2012 Road Glide Custom--Gone But Not Forotten
JDisMe is offline
post #2 of 11 (permalink) Old 07-11-2017, 09:04 PM
With the bars cock to the left or not?
reds4 is offline
post #3 of 11 (permalink) Old 07-11-2017, 09:15 PM Thread Starter
JDisMe's Avatar
Yes. The bars are all the way to the left.
Sent from my SM-N920V using Tapatalk
--2019 RGS--
JDisMe is offline
post #4 of 11 (permalink) Old 07-12-2017, 04:58 AM
BH#103's Avatar
Go to a dealer and check a couple two three other bikes for the same noise. I think I know the noise you are hearing. Like a metallic ching/clunk noise? I'm pretty sure all of them do it, some just more pronounced. You can always pull the whole switch assembly out for a closer look. They are very easy to disassemble and reassemble if you are paying attention. Is there resistance when you turn it?
BH#103 is offline
post #5 of 11 (permalink) Old 07-12-2017, 04:10 PM Thread Starter
JDisMe's Avatar
It is just that, like a metallic ching. I noticed if I turned it really slow, sometimes it wouldn't make the noise at all.
Very strange. I'm just wondering if I'm damaging anything by doing it.
I'll try to get a video of it later tonight.
--2019 RGS--
JDisMe is offline
post #6 of 11 (permalink) Old 07-12-2017, 08:48 PM
BH#103's Avatar
You are only a blast down the highway from me. Let me know if you need a hand, an extra eye or even my scoot to compare it to. I had the noise I am describing on my 2012 and even on my '15. The '12 was quite a bit more pronounced.
JDisMe likes this.
"SLIVER"
BH#103 is offline
post #7 of 11 (permalink) Old 07-13-2017, 09:39 AM Thread Starter
JDisMe's Avatar
Much appreciated BH. It never made the noise before so that's why it's such a thorn in my side, lol.
I haven't spent time on it as I was out working all night when those storms came through Tuesday night.
I've done everything but slide a screwdriver down there and turn it counterclockwise.
--2019 RGS--
JDisMe is offline
post #8 of 11 (permalink) Old 07-13-2017, 10:07 AM
WTFranz's Avatar
Almost sounds like the spring maybe catching. I have had mine out several times and I think If I remember correctly one end of the spring is flatter.. if that makes since? Maybe try flipping the spring over could be catching and twisting.
Mazikeen - 2016 Road Glide Special from Arizona
WTFranz is offline
post #9 of 11 (permalink) Old 07-13-2017, 10:30 AM Thread Starter
JDisMe's Avatar
I will definitely look at that, easy enough to check. Thanks for the heads up, I didn't really scope out the spring edges.
--2019 RGS--
JDisMe is offline
post #10 of 11 (permalink) Old 07-13-2017, 10:33 AM
JayKS's Avatar
What octane fuel are you running?
( C'mon, I can't be the only smartass that was thinking this. )
calgaryglide likes this.
JayKS is offline
Removing your ignition switch joke Do-IT-Yourself 21 01-05-2019 02:18 PM
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 07:18 AM
ping... Ping... PING philmartin *General Road Glide Discussions/Pictures 20 07-25-2011 09:10 PM
Chrome Ignition Switch Cover for Road/Glide cestaro Aftermarket Accessories 4 06-06-2011 05:17 AM
Heard a "PING!" when riding today okcdoughboy *General Road Glide Discussions/Pictures 26 05-06-2011 11:03 AM
