Replacing 10" Monkeys with 12" do I really need extensions - Road Glide Forums
 2Likes
  • 1 Post By Swomack
  • 1 Post By QNman
post #1 of 10 (permalink) Old 07-17-2017, 08:13 AM Thread Starter
ashnic's Avatar
I am replacing my 10" Yaffee Monkey bars with 12" on Bagger******* it says I need extensions..really? I know some of the wiring might be slightly tight but need extensions? Anyone? These are going on a 17 RGS. Also if I need extensions where can I get them. Will the clutch and brake lines be ok? Man I know this has been beat to death but I see where Factory47 are good up to 14". Any help would be greatly appreciated.
2017 Road Glide Special
ashnic is offline
post #2 of 10 (permalink) Old 07-17-2017, 08:22 AM
Swomack's Avatar
You will have zero issues using the stock cables & wiring with 12" bars.
I had 13" apes before going with 16" bars and the cables and wiring worked out perfect.
Now on the 16" apes I went ahead and swapped out with steel lines and wiring extensions.
I say pull the trigger on the bars and you should be good to go.
Good Luck.
Swomack
moose1 likes this.
My Gallery / Click Below Link
Swomack is offline
post #3 of 10 (permalink) Old 07-17-2017, 08:49 AM Thread Starter
ashnic's Avatar
Thanks my friend...feel a whole lot better tearing her down...
ashnic is offline
post #4 of 10 (permalink) Old 07-17-2017, 08:56 AM
Swomack's Avatar
Are you sure you don't want to go with 14" apes ?
I would bet you would really like them even more then the 12" apes.
They feel great and look badass for sure.
I had 13" apes and then swapped them out with 16" apes.
Couldn't be happier.
Just a thought brother.
Looking forward in seeing what you end up selecting and seeing some updated pictures.
Swomack
Swomack is offline
post #5 of 10 (permalink) Old 07-17-2017, 09:20 AM
SteadyEddie's Avatar
Not sure of your size and reason for swapping out but can say for me, at 5'11 with a 34 inseam and running a CVO seat that has me back and down an inch in both directions, I came from 12 inch HD Tall Boys to 9 inch HD Chizzled Lows and LOVE the performance of the smaller bar height - No "flex" in the bars, easier to push the bike around and personally, I feel more in control in sweepers and tight stuff with a lower center of gravity as it pertains to bar height.....you can get that "push down pull up" going like you can from flat MX Bars - I am sure I am the exception and don't get me wrong, I LOVE the looks of Apes and had a Wide Glide with 18s that was just tits on a taco......but these 9 in Chizzled Lows have me dialed in when I am leaning the bike over
SteadyEddie is offline
post #6 of 10 (permalink) Old 07-21-2017, 11:55 AM
QNman's Avatar
I have the 14" Yaffee Monkey Bars - stock hydraulic lines all around. The instruction video on Factory 47 works the same for Yaffee.
I'm 5'-10" with a 30" inseam (all torso). The 14" bars are about 1" below my shoulders. I debated back and forth between 12" and 14", but decided to be risky. Now, I can't even imagine my bars being lower.
ETA: Don't forget to change the bushings to polyurethane ones. With the new stiffer bushings, I don't get any slop in the handlebars at all. I find it as easy or easier to control with the apes over stock, and WAY more comfortable.
Swomack likes this.
2016 FLTRXS, Stage 2 motor, Boom! Stage II audio. Black Quartz.
QNman is offline
post #7 of 10 (permalink) Old 07-31-2017, 12:20 PM
Jlong's Avatar
Did you have to use any wire extensions? Also, would the fit be the same on a 2011 FLTRU? I'm 6' tall and trying to decide whether or not to get the 12" or 14" Yaffe Monkey bars, but I hear many people saying you don't need to buy anything extra except maybe bushings.
Jlong is offline
post #8 of 10 (permalink) Old 07-31-2017, 01:41 PM
QNman's Avatar
I don't know if I "needed" the wire extensions, but I installed them. On the 2016, it's a no-brainer, as you don't have to unpin the couplings.
Regardless of whether you go 12" or 14", you absolutely SHOULD replace the bushings. The rubber ones just aren't solid enough for the increased torque of the substantially taller apes.
I don't know how much of this translates to the 2011, but overall height certainly should.
QNman is offline
post #9 of 10 (permalink) Old 07-31-2017, 02:30 PM
Heavvyduty's Avatar
These bushing yer talking about. Do the 2017 have them also?
Heavvyduty is offline
post #10 of 10 (permalink) Old 07-31-2017, 02:50 PM
QNman's Avatar
Yes, they do... Part number 8 - Parts Finder The Outpost Alaska
QNman is offline
Really dumb shock question--- replacing 12" with 13" IndyIN Suspensions 12 08-25-2015 07:59 PM
Got 10 inch Yaffe Monkeys, weird measurement, need advice gframe Controls & Handlebars 5 02-20-2014 04:09 PM
Clutch cable for 12" PYO monkeys jefflew Controls & Handlebars 0 05-05-2012 09:11 AM
10" Monkeys On, But... MakeARunMike Controls & Handlebars 4 03-13-2012 07:31 PM
Show me your 12" OEM Monkeys RedDogNC Controls & Handlebars 4 02-24-2011 09:35 PM
