2012 handlebar bushings help - Road Glide Forums
post #1 of 5 (permalink) Old 07-27-2017, 11:08 AM Thread Starter
WIKD1's Avatar
I have been having an unusual amount of flex in my handlebars so I decided to install polyurethane riser bushings. I really didn't expect it to be much of an issue to replace, but I can't seem to get to the bolt heads. There's a cover right below them. I looked in my service manual, but it just says to remove the bolts to remove the lower mount, it doesn't mention how to get to the bolts with that mount/cover in the way. Any recommendations would be appreciated.
WIKD1 is offline
post #2 of 5 (permalink) Old 07-27-2017, 11:46 AM
BH#103's Avatar
All you should have to do is turn the handlebars left to access the right bolt and right to access the left bolt. It's easier to crack them loose with the handlebars still on. Hope this helps you, good luck!
BH#103 is offline
post #3 of 5 (permalink) Old 07-27-2017, 01:16 PM
JDisMe's Avatar
What he said. I have a '12 RGC and just did mine too while I did the bars. I used a deep socket and an extension to get up in there and crack them.
I noticed mine had red Loctite on them, but I put blue Loctite on when I put them back in, per the manual.
--2019 RGS--
--2012 Road Glide Custom--Gone But Not Forotten
JDisMe is offline
post #4 of 5 (permalink) Old 07-27-2017, 03:32 PM Thread Starter
WIKD1's Avatar
Thanks Guys. You'd think I would have been smart enough to figure that one out. Sorry.
Any advice when installing? I'm guessing I should get the bolts in far enough to clear and then put the clamps together before tightening. Sound right?
2012 HD Road Glide
Brotherhood Above All.
WIKD1 is offline
post #5 of 5 (permalink) Old 07-27-2017, 05:02 PM
Mike U's Avatar
WIKID1, When Installing the bolts make sure they are in far enough to clear underneath before turning the bars otherwise the bolt head will catch and you'll have trouble turning them.
If you run into any problems don't hesitate to ask here on Our Great Forum.
Hope this helps.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
Handlebar Vibration and Riser Bushings AAbiker Controls & Handlebars 0 06-17-2014 05:43 PM
Alloy Art Handlebar Bushings are taller ? kevanbo Controls & Handlebars 5 05-17-2014 09:15 PM
Change out bushings with handlebar swap? equandt Controls & Handlebars 18 08-14-2013 10:47 PM
Polyurethane Handlebar Riser Bushings longrides Miscellaneous for Sale 0 09-16-2012 06:11 PM
Handlebar Riser Bushings for Apes? Tek74 Controls & Handlebars 3 02-24-2012 11:33 AM
