2012 Road Glide Cruise Control issues - Road Glide Forums
post #1 of 4 (permalink) Old 08-10-2017, 07:40 AM Thread Starter
Greetings fellow Road Glide enthusiast!
I've read a number of posts on this issue and am still perplexed. My cruise control stopped working (bike has almost 70,000). the red light in the gauge is out (thinking about opening it up to see if it's burnt out), but the switch light still works. I'm having trouble locating the fuse to check it. Hoping it is as simple as that and looking for direction on where it might be located. No trouble with the brake light switches, so that's not the cause I'm assuming. Wondering if the switch in the controls would cause the light not to work in the gauge.
Your help is greatly appreciated,
Blademn
Blademn is offline
post #2 of 4 (permalink) Old 08-10-2017, 03:08 PM
Dice21's Avatar
Not 100% if the 12 has it, but on the newer bikes if the gear indicator isn't working, the cruise will turn on, but not set.
I had it happen to me a few times. It would be on, and then shut off when the indicator blinked. Not much fun on the hiway.
Maybe something to look at.
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #3 of 4 (permalink) Old 08-10-2017, 03:30 PM
Thermodyne's Avatar
There is a diagnostic ladder to determine what's failed. You'll find it in section 5 of the electrical diagnostic manual.
The power comes from the accessory fuse.
And there are some fault codes that disable the cruise, so check them first.
Thermodyne is offline
post #4 of 4 (permalink) Old 08-11-2017, 08:43 AM
There is also a switch on the clutch that will enable/ disable the cruise. That switch will disable the cruise if you are riding with the cruise set and pull in the clutch, it is there to prevent over revving the engine.
Does the 2018 base Road Glide have a Cruise Control? Slider57 *General Road Glide Discussions/Pictures 21 02-11-2018 09:02 AM
2012 Cruise Control intermittant? Jimbosan Troubleshooting for Road Glides 10 10-06-2017 09:10 PM
RG cruise control CEL issues Diverrick *General Road Glide Discussions/Pictures 3 09-05-2015 08:04 PM
thundermax cruise control issues milkman48 ECM/Fuel Management systems 17 04-19-2014 09:39 AM
Cruise Control issues Cheesyrider Controls & Handlebars 4 04-05-2012 04:37 PM
