Which wire extensions? - Road Glide Forums
post #1 of 6 (permalink) Old 11-26-2010, 03:17 PM Thread Starter
CustomGlide's Avatar
Send a message via AIM to CustomGlide
I have been told it is easier to run the wires through the bars by getting wire extenders because of the smaller plug. I realize they are not needed, but which ones should I get and how long? i am not sure how this works as well, so any instruction will be apreciated. I realize this topic has been covered several times over, but I am a slow learner. Thanks in advance!
CustomGlide is offline
post #2 of 6 (permalink) Old 11-26-2010, 07:09 PM
Carisma Audio's Avatar
I have used the plug in ext and sometimes they come unplugged, so now its all solder and heat shrink staggerd joints and its allways perfect
Carisma Audio is offline
post #3 of 6 (permalink) Old 11-27-2010, 03:37 AM
gja
Little more info could make a big difference. Year of bike, rise of new bars etc.
You may not need extensions if your bars are 12" or less. I just did my Khromewerks +2 sweepers and didn't change anything except the twist grip sensor. Changed that out to the one without the plug (part # 32310-08). Everything is internal now and this is with 1" bars.
gja is offline
post #4 of 6 (permalink) Old 11-27-2010, 03:38 PM Thread Starter
My bike is a 2010 RG. Going with 12" Monkey Bars. I know the extensions are not needed, I am just looking for which extensions to get to eliminate the large OEM plug, or at least get a smaller plug to make it easier to slide through. I would really like to get rid of the plug (without soldering) if possible?
post #5 of 6 (permalink) Old 11-27-2010, 04:30 PM
gja
If you're talking about the green plug on the TBW, part # 32310-08 is what I used. Eliminated the plug completely.
A tip for taking the plug off the end of the upper controls is to use a small paperclip. Bend it out straight and it fits in the hole to release the individual wires.
gja is offline
post #6 of 6 (permalink) Old 11-27-2010, 08:09 PM Thread Starter
Thank you Gja. That is what I was looking for.
Thank you too Carisma
14" buky malo wire extensions?? bigpimpn916 Controls & Handlebars 1 02-18-2014 04:12 PM
Cables and Wire Extensions? RhinoHD Controls & Handlebars 11 04-10-2013 05:31 PM
What gauge wire extensions are needed? 2012FLTRU_BigBlue Controls & Handlebars 5 04-10-2013 01:11 AM
need ADVICE for doing wire extensions h-donut Controls & Handlebars 25 03-05-2013 11:13 PM
Novello Wire Extensions BigBoy Controls & Handlebars 2 10-24-2011 03:35 PM
