2006 Handlebar upgrade - Road Glide Forums
post #1 of 11 (permalink) Old 04-28-2013, 09:36 AM Thread Starter
Hi guys,
I am 6'1", and I find the bars too low. I want to change the bars, however I don't want to change cables or wiring. What is the tallest bar I can go to without modifications? I want something with more height & pullback. I plan to check out the Heritage bars this week at my local shop, however I don't know if they will be tall enough.
Thanks,
Guy
Fillatre is offline
post #2 of 11 (permalink) Old 04-28-2013, 11:33 AM
Originally Posted by Fillatre View Post
Hi guys,
Thanks,
Guy
Get what fits you the first time. You'll save money in the long run since you'll probably end up with longer cables anyway. Experimenting gets expensive quick.
I naturally started with the stock bars. Then I went to Wide Glide bars. They I went to HD mini apes (13" from top of the bend at the grip to the bottom of the bend at the clamp) and the throttle cables were okay, but I had the wires on the outside and had to go with a longer clutch cable. Now I have 19s and the old extended clutch cable worked but I had to get new throttle cables and extend the wires by about 6".
SickRick is offline
post #3 of 11 (permalink) Old 04-28-2013, 02:52 PM Thread Starter
Thanks. I know I only want to go a few inches over stock, just wondering what the max is without changes.
Fillatre is offline
post #4 of 11 (permalink) Old 04-28-2013, 03:06 PM
About 12" on the brake line. That's what the Heritage style bars are I have and the brake line is at its max. Clutch got maybe an other inch.
Get what you want and don't worry about cables. There easy and inexpensive to replace. The wiring on both sides should have enough slack to reach 16" s .
post #5 of 11 (permalink) Old 04-28-2013, 03:50 PM Thread Starter
Thanks. I will know this week if the Heritage bars are comfortable.
Cheers,
Guy
Fillatre is offline
post #6 of 11 (permalink) Old 04-28-2013, 05:39 PM
Cheers,
Guy
Now I have the Heritage style bars for TBW. If you go true Heritage bars Non tbw check the difference in dimensions between the two.
post #7 of 11 (permalink) Old 04-28-2013, 07:28 PM
Thanks. I know I only want to go a few inches over stock...
Yeah, that's what I said originally.
SickRick is offline
post #8 of 11 (permalink) Old 05-06-2013, 09:34 AM Thread Starter
Heritage bars installed, and so far I am happy. Need a couple of long runs to be 100% sure. No issues with wires or cables.
Fillatre is offline
post #9 of 11 (permalink) Old 05-06-2013, 09:43 AM
Good deal.
post #10 of 11 (permalink) Old 05-06-2013, 11:20 PM
Nifty-50's Avatar
I have a pair of Todd's 12" Strip for 06 for sale, $190 plus shipping
Nifty-50 is offline
Handlebar Upgrade!!! cbruder35 Audio 1 09-16-2017 07:02 PM
Stock 18" from a 2010 RG on a 2006 RG miked Aftermarket Accessories 4 03-28-2011 06:24 PM
AM FM Antenna for 2006 Road Glide. kimmer127 Aftermarket Accessories 1 07-17-2010 10:04 AM
2006 seat cover Dry Heat Seating: seats, backrests 2 05-19-2010 08:01 PM
Will 2010 RG parts fit on a 2006 RG? jaerikd510 *General Road Glide Discussions/Pictures 9 04-18-2010 02:17 PM
