Sticking throttle - Road Glide Forums
post #1 of 9 (permalink) Old 04-29-2013, 09:57 AM Thread Starter
Sticking throttle
OK. I have an 04. Bought used. The handle bars were not stock, they were a little shorter . The throttle stuck. So i replaced the bars with stock ones, put new grips on and oiled the cables. It still sticks. My kids street glide snaps back imediatly. Everything looks ok. Check the spring on the throttle body. All ok
Could the cables be too long? I bAsically have to operate the throttle oped and closed. Any help?
TC308 is offline
post #2 of 9 (permalink) Old 04-29-2013, 10:10 AM
That should be able to be adjusted out if the cables are good. The adjustment will be on the throttle side of the push pull cables. When you oiled them did you manually work the cable by hand ?
post #3 of 9 (permalink) Old 04-29-2013, 10:22 AM
PGR
PGR's Avatar
Make sure you didn't slide the housing inboard to far. The grip could be sticking on the end of the bar.
Ron..........................
PGR is offline
post #4 of 9 (permalink) Old 04-29-2013, 10:28 AM
Also check your throttle lock if it doesn't have cruise control.
post #5 of 9 (permalink) Old 04-29-2013, 10:29 AM Thread Starter
Yes. They felt free. Were is this ajustment you mentioned? And also, if i turn the bars alway to the left, it tightenes more.
TC308 is offline
post #6 of 9 (permalink) Old 04-29-2013, 10:57 AM
On the end of the cables. (Throttle side).
post #7 of 9 (permalink) Old 04-29-2013, 12:56 PM Thread Starter
Ooohhh...i feel like a DB...i know what you mean. You think the return one might be too loose?
TC308 is offline
post #8 of 9 (permalink) Old 04-29-2013, 04:46 PM
Or vice versa
post #9 of 9 (permalink) Old 04-29-2013, 06:34 PM Thread Starter
Thanks! I will give it atry and let you know how it works out.
TC308 is offline
2015 FLTRXS Rear Brake pedal sticking Dabull67 Wheels and Tires 1 08-22-2015 07:44 PM
Sticking throttle garbage cannon Controls & Handlebars 9 06-19-2014 02:22 PM
My voltage meter looks like it is sticking??? Louster47 Troubleshooting for Road Glides 4 02-21-2014 09:17 AM
Keeping Bugs From Sticking.... Roadglider09 *General Road Glide Discussions/Pictures 23 12-18-2013 10:59 AM
Throttle sensor sticking...no, it's not the grip! DC-3Mek Controls & Handlebars 12 10-13-2012 10:56 PM
