Newbie Question - Road Glide Forums
post #1 of 8 (permalink) Old 11-11-2017, 09:05 AM Thread Starter
Newbie Question
Piggy backing on a post by Hiram, I think the original owner rolled the stock bars forward. So far forward that they're uncomfortable, and are too close to the fairing when turning lock to lock. I'd like to roll them back rather than install new bars. I'm guessing I'll have to re-index the controls but have read about the controls and handlebars being locked in place by pins...Assuming the original owner didn't mess things up too badly I should be able to put them back where they were? I'm 6'2 and the seat is stock.
Vertol is offline
post #2 of 8 (permalink) Old 11-11-2017, 09:07 AM Thread Starter
That's the only picture I have...
Vertol is offline
post #3 of 8 (permalink) Old 11-11-2017, 09:24 AM
bucketlisthd's Avatar
The pins on the controls snap off
surprisingly easy.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #4 of 8 (permalink) Old 11-11-2017, 09:24 AM
Swomack's Avatar
It’s a 15 minute job and yes you will be able to roll them back without any issues.
Loosen up everything and set it the way you like it, and tighten it back up, and your good to roll.
Nice Bike
Swomack
My Gallery / Click Below Link
Swomack is offline
post #5 of 8 (permalink) Old 11-11-2017, 10:25 AM
BlazingSaddle's Avatar
Rest easy, nothing’s messed up and nothing is “locked” in place. There is (probably in your case “was”) a pin in the bottom half of the bar clamp that apparently is placed there during assembly for purpose of quick and easy standard alignment. It’s usually removed or tamped down when changing handlebars. Some bar manufacturers do not have the slot to accommodate the pin, others only place the slot on one side of the bar, like Factory 47, but RGU’s and CVO’s have the pin on the opposite side of the clamp, requiring removal of the pin for those bars, or as in your case the owner wanted to move the stock bars further forward than would be allowed with that pin in place.
There are several videos on handlebar replacement. You only need to remove the gauge cluster in order to loosen the clamp enough to get your bars where you want them. I’d suggest a helper to hold the bars at all times, and always protect your tank with a cover. Two popular videos are “Factory 47 2015 2016 Road Glide 14” Handle Bar Install”, and “How to install 13 tall Road 6 Custom Handlebars”. I wouldn’t recommend removing the ignition switch to do it because one wrong move and you’ve got another project on your hands. This means you’ll have to remove the horseshoe underneath the ignition switch. They’re only clipped in but some are easier to remove than others. Piece of cake though.
BlazingSaddle is offline
post #6 of 8 (permalink) Old 11-11-2017, 10:34 AM Thread Starter
Thanks for talking me off that ledge...Since my riding season here in the great white north is over, I'm just gonna take my time and stare at it for a good long while
Vertol is offline
post #7 of 8 (permalink) Old 11-11-2017, 10:47 AM
madmat's Avatar
+1 on this ^^^^^^^^^^^^^^^^, there is also a quickie youtube video on removing the chrome switch cover. Goggle is your freind.
18 RGS Bonneville Salt Pearl
madmat is online now
post #8 of 8 (permalink) Old 11-12-2017, 06:08 PM
PSUUUUU's Avatar
Super easy fix. Two screws to remove the odometer/speedo. Then four bolts to remove the neck stem.
PSUUUUU is offline
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
Newbie question, comparison of Mustang, Maverick, Sundowner dawgcasa Seating: seats, backrests 10 05-26-2012 09:16 PM
Question from a newbie on '12 RG Custom pricing dawgcasa *General Road Glide Discussions/Pictures 19 04-17-2012 03:03 PM
Newbie exhaust & intake question... mjohnson68 Intake and Exhaust 14 02-20-2012 07:19 PM
Newbie warranty question musicman8120 *General Road Glide Discussions/Pictures 4 08-19-2010 05:53 PM
