controls position - Road Glide Forums
 3Likes
  • 1 Post By bucketlisthd
post #1 of 9 (permalink) Old 11-11-2017, 01:21 PM Thread Starter
controls position
I just installed new Road6 customs Standard Apes, 11 inches. All the install went smoothly. I was out riding yesterday and decided that I would like to rotate the bars back and down about another inch or so.
The problem I am running into is this: The bars have all the holes and notched that match the original bars.
The connectors for the brake and clutch levers have a pin in them. This pin fit into a hole notched in the handle bar.
All in all, this hole and pin limit the amount of swivel room.
As I move the bars down, I want to move the whole control attachments up. That is to rotate them toward the top of the bars.
Has anyone ever knocked off those pins in the levels clamps to move the controls?
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #2 of 9 (permalink) Old 11-11-2017, 05:48 PM
bucketlisthd's Avatar
Yes, I have knocked the pins off of the controls, and on the exact same bars, oddly enough. I put the part on a solid wooden surface, used an old screwdriver as a standoff, and hit it with a hammer. I was assured that it was a simple job, and it was. The pins break off clean. I may have licked the stubs with a file, can't remember.
pauld likes this.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is online now
post #3 of 9 (permalink) Old 11-11-2017, 06:02 PM Thread Starter
ok
May I assume they are holding fast??
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #4 of 9 (permalink) Old 11-11-2017, 08:12 PM
Yup, holding fast. The handlebar pin has been out for 2 years, and the control pins have been snapped off for 1 year. No issues.
pauld likes this.
'87 FXR 100"
'79 Goldwing cafe
post #5 of 9 (permalink) Old 11-12-2017, 12:50 PM Thread Starter
Knocked off pin with hammer and big screw driver. Minimal filing.
Now that I have adjusted the hand controls, the angle of the banjo bolts leaves little room for the line curve before it hits the handle bars.
Is it possible to adjust the angle on banjo bolts without loosing fluid? Will I have to go through a bleed down process?
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #6 of 9 (permalink) Old 11-12-2017, 04:17 PM Thread Starter
found out
<--found out. just loosen a tad, move and re-tighten.
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #7 of 9 (permalink) Old 11-12-2017, 05:11 PM
Yes it is. I did it. Crack the banjo bolt just enough so that it is moveable. No bleeding was needed.
pauld likes this.
'87 FXR 100"
'79 Goldwing cafe
post #8 of 9 (permalink) Old 11-13-2017, 10:04 AM
I was scared to snap off the pot metal pin. I hit it with a cutoff wheel. No problems.
Buzzy is online now
post #9 of 9 (permalink) Old 11-13-2017, 12:17 PM
I was scared myself, but was assured by other forum members that they snap right off with a screwdriver and a hammer. They really do. I was pleasantly surprised.
'87 FXR 100"
'79 Goldwing cafe
Arm/Hand Position Vs Neck Pain Swampratt Controls & Handlebars 19 06-03-2012 07:54 AM
Kendon 2 position stand-up trailer - Denver, CO rogerfromco Sold 8 04-29-2012 02:01 PM
KObalt jack won't raise up from lock position jimmyray11349 *General Road Glide Discussions/Pictures 3 11-04-2011 08:19 AM
Riding Hand Position - RGU waco54sp Road Glide Specific Discussions 31 10-20-2011 06:52 PM
Danny Gray Big Seat position? TDavis Seating: seats, backrests 5 05-21-2011 08:01 AM
