did you do away with the green connector totally ? - Road Glide Forums
post #1 of 20 (permalink) Old 05-02-2013, 09:45 AM Thread Starter
rob883's Avatar
i had someone tell that you have to keep the green connector with the TBW.That does not make sense to me at all .......
1969 XLCH sold 1972 XLH sold 2002 Dyna Defender
2002 Ultra Electra Glide sold 2013 RoadGlide Ultra
1986 FXRD great bike !!
rob883 is offline
post #2 of 20 (permalink) Old 05-02-2013, 09:48 AM
Rowdy's Avatar
Mine is hardwired. I got rid of the connector when I changed out my bars from Yaffee to what I have now.
Rowdy
Rowdy is offline
post #3 of 20 (permalink) Old 05-02-2013, 10:31 AM
moleng1's Avatar
Are there any pics/info on how to remove the green connector (besides buying the CVO TBW, before all you smart asses jump in, lol)
Some people are like slinkies.............
They"re really not good for anything, but they still bring a smile to your face when you push them down a flight of stairs
moleng1 is offline
post #4 of 20 (permalink) Old 05-02-2013, 10:35 AM
I removed mine completely - gave me nothing but trouble when I internally wired 14" Outlawz. Just pulled the pins out of each side, cut them off, stripped 1/2 - 3/4" on each side, twisted together, solder - heat shrink each wire, then wrapped the bundle in electrical tape. No issues. Just keep track of which wire goes to which - on the "down" side you have 6 colors, "up" side you have just red, white and black. Getting them right is critical to functionality. I think Donk had a post that tells you which color is which, but just diagram it and you'll be ok.
Good luck,
G
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Those white lines are just Road Chum ... and my Shark is HUNGRY!
2012FLTRU_BigBlue is offline
post #5 of 20 (permalink) Old 05-02-2013, 12:37 PM
TimMCc's Avatar
I didn't even give it a second thought, hardwired mine and never had an issue after two different sets of bars.
Hold fast!
TimMCc is offline
post #6 of 20 (permalink) Old 05-02-2013, 12:46 PM
RedneckMedic66's Avatar
I left mine in but I have 1.5in bars and didnt have an issue wiring. If you have some type of 90* bend or similar I would for sure hard wire.
GLIDE OR DIE!!
RedneckMedic66 is offline
post #7 of 20 (permalink) Old 05-02-2013, 07:42 PM
Ezgravy's Avatar
I say hard wire it. I just did this last weekend. Find the Donk sticky and you won't go wrong. That green connector seems a little weak to me and it was going to be too hard to get it inside the bars with everything else.
EZ
Silence is golden.....duct tape is silver.
Ezgravy is offline
post #8 of 20 (permalink) Old 05-02-2013, 08:20 PM
Dmize's Avatar
Cut mine out. Glad I did.
D.Mize
16 CVO RGU
Dmize is offline
post #9 of 20 (permalink) Old 03-31-2014, 03:34 PM
937shanegalb's Avatar
What guage wire did you use to hard wire? looking at doing a bar swap this weekend.
937shanegalb is offline
post #10 of 20 (permalink) Old 03-31-2014, 03:47 PM
stripclub's Avatar
Mine is cut out also, just cut one wire at a time on both sides of the plug, splice the two wires together, solder the connection and heat shrink.
stripclub is offline
If you're running an amp, what did you do for an antenna? anonymous_1 Audio 17 08-31-2016 01:11 PM
TBW green connector dochawken Controls & Handlebars 8 05-21-2014 09:26 AM
SE green connector upgrade on twist grip sensor fat boy ultra Controls & Handlebars 5 04-23-2013 08:26 PM
Totally Satisfied Customer direwolf Sancho's Wings 1 04-12-2011 12:24 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
