changed handle bars wont start now - Road Glide Forums
post #1 of 12 (permalink) Old 05-03-2013, 09:25 PM Thread Starter
rob883's Avatar
i put on some yaffe 14 apes.I fired it up and checked all my functions.The switches on both sides worked fine.I just had fired it up ,,,,,it was idling then just died.When i go to crank it the ignition comes on in the right spot the icon on the speedo does not and i do not hear the fuel injection turn on ........................any ideas
1969 XLCH sold 1972 XLH sold 2002 Dyna Defender
2002 Ultra Electra Glide sold 2013 RoadGlide Ultra
1986 FXRD great bike !!
rob883 is offline
post #2 of 12 (permalink) Old 05-03-2013, 09:42 PM
Did you remove the tank for any reason? Check the fuel line connection. Otherwise, probably a loose connection? Re-seat the connectors and try again.
Good luck,
G
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Those white lines are just Road Chum ... and my Shark is HUNGRY!
2012FLTRU_BigBlue is offline
post #3 of 12 (permalink) Old 05-03-2013, 09:42 PM
Harleyagain's Avatar
Ummm. Start with the fuse first. If not then most likely it's the infamous green connector! Several threads on this with the same symptoms.
Good luck!
Bob
Harleyagain is offline
post #4 of 12 (permalink) Old 05-03-2013, 09:56 PM Thread Starter
rob883's Avatar
green connector is totally gone.It fired right up and idled for about 4 min then died.The red key keeps flashing on the speedo.
rob883 is offline
post #5 of 12 (permalink) Old 05-03-2013, 10:47 PM
jimmym1981's Avatar
I would start with fuses as well. If that is not an issue, most likely it is a connection. Check the connectors and unfortunately if those are good, you might have to check the wires.
2013 FLTRX Candy Orange
16" Malos/4" Rineharts /Ness Big Sucker/PCV/PBR300x4/Hertz Hi-Energy 6.5's
jimmym1981 is offline
post #6 of 12 (permalink) Old 05-04-2013, 07:04 AM
bronxbill's Avatar
If the red key is flashing, that means there is a code thrown. Check the codes, it might help you narrow it down.
2013 Roadglide Ultra Midnight Pearl, Vied's, Mach2 Air Cleaner, Screamin' Eagle Slip Ons, LRS 13' Mako Windshield, Edge Cut Billet Saddlebag Latches, CVO Mirrors, Black Heritage Style Bars with Edge Cut Levers, Chromedome Horn Cover, Mean Mug Bezel, Pinstiping by Wild Bill
bronxbill is offline
post #7 of 12 (permalink) Old 05-04-2013, 03:21 PM
cbrittingham's Avatar
Agreed, if there is a ground somewhere with the connections or wires. You will pop a fuse and it won't prime/turn over. Other things will work, cause they run off different fuses. I had the same issue with my bars cause the insulation around the wires INSIDE the bars was rubbing. It was a nightmare.
cbrittingham is offline
post #8 of 12 (permalink) Old 05-04-2013, 07:35 PM
if the ck engine light does not come on check the ignition fuse , it powers that light and the ignition module .
Eagle
Eagle is offline
post #9 of 12 (permalink) Old 05-05-2013, 08:27 AM
Remember when doing all your checks that the bike will not start with the headlights unplugged.
SNOOP4488 is offline
post #10 of 12 (permalink) Old 05-06-2013, 06:46 AM
This was not true on my 2012 RGU. Could start mine no problem with headlights unplugged while troubleshooting. FWIW
Cheers,
G
Changed bars now alarm goes on bike won’t start hd4cruzin Controls & Handlebars 11 02-28-2018 06:19 AM
Bike wont start Bluchevypick Troubleshooting for Road Glides 50 01-26-2014 12:15 AM
2012 RGU wont start after cam swap Bluchevypick Troubleshooting for Road Glides 5 04-20-2012 10:35 PM
changed bars now bike wont start NO4NBIKES Controls & Handlebars 4 01-02-2012 10:06 AM
wont start The instigator Road Glide Specific Discussions 8 03-24-2011 09:20 PM
