Cruise control - Road Glide Forums
post #1 of 5 (permalink) Old 11-25-2017, 06:27 PM Thread Starter
Cruise control
I've had my 2011 rg custom for about 2 months, and there are times that the cruise control doesn't want to set. The times that it does, when i have to slow down, or stop it doesn't always want to resume. It is always kinda hit and miss if cruise is gonna work or not. Has anyone else had this problem?
shawn431783 is offline
post #2 of 5 (permalink) Old 11-25-2017, 06:59 PM
Make sure your brake switches are disengaging. (Not sticking on). 2010-2011 had a rear brake switch recall.
post #3 of 5 (permalink) Old 11-25-2017, 09:07 PM
ERod62's Avatar
Brake and clutch disable cruise control when active, if slowing down by engine braking or braking cruise will be disable.
ERod62 is offline
post #4 of 5 (permalink) Old 11-26-2017, 01:22 AM
Clutch1's Avatar
Make sure your brake lever goes all the way back out after using it as well as the clutch lever. I found mine wasn’t and it took me awhile to track it down. There seemed no rhyme or reason when it would or wouldn’t resume. I put in new bushings and the problem went away.
04 RG
Clutch1 is offline
post #5 of 5 (permalink) Old 11-26-2017, 11:33 AM
Thermodyne's Avatar
There is a test sequence in the electrical repair manual, it's basically self diagnosing with some rider input to cycle the switches.
Beyond that, the thumb switches are susceptible to moisture, and the wire can break, inside the insulation, where they cross from the steering head back to the main harness.
Thermodyne is offline
Tags
controls , cruise control
Cruise control shutting down rocun Troubleshooting for Road Glides 22 10-29-2014 06:48 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
2011 FLRTU Cruise Control//engine light/windshield SquirtRGU Road Glide Specific Discussions 47 12-09-2011 04:36 PM
Cruise Control won't maintain speed BigTirez Troubleshooting for Road Glides 4 10-17-2011 09:04 PM
Cruise control kit for FLHR 2008 AND LATER MrFah Classifieds Archive (3 months old+) 0 09-02-2010 01:56 PM
