Need torque value - Road Glide Forums
post #1 of 6 (permalink) Old 05-05-2013, 09:15 AM Thread Starter
Need torque value
What is torque value for the bolts holding on handle bar clamp when installing urethane bushings?
Thanks
Steve
platinum69 is offline
post #2 of 6 (permalink) Old 05-05-2013, 10:41 AM
Triplej's Avatar
Lower Clamp Bolt Spec = 30-40 ft.-lbs. - (Apply 2 or 3 drops of Blue Loctite)
Upper Clamp Screws Spec = 16-20 ft.-lbs. - (no mention of Loctite in the manual for these screws)
Picture added to eliminate any confusion. Broken bolts are no fun. (4) Screws item number 15 should be torqued to 16-20 ft. lbs. in the order staush provided. (2) Bolts item number 1 should be torqued to 30-40- ft. lbs. using the Blue Loctite.
Triplej is offline
post #3 of 6 (permalink) Old 05-05-2013, 10:48 AM
staush's Avatar
handlebars
In my 2011 manual it says the handlebar clamp should be torqued to 16-20 foot-lbs. All 4 screws. bottom screws first then top screws.
staush is offline
post #4 of 6 (permalink) Old 05-05-2013, 01:37 PM Thread Starter
Great thanks for that!
Where can I find online manual for 09RG?
post #5 of 6 (permalink) Old 05-05-2013, 05:48 PM
Thanks
Steve
Tighten until the bars don't slip in the clamp when pushing the broken down bike along the shoulder of the road.
SickRick is offline
post #6 of 6 (permalink) Old 05-05-2013, 07:00 PM
Triplej's Avatar
You can find your online parts microfiche here,
Www.shopronniesharleydavidson.com
Triplej is offline
Shifter linkage torque value. jcarruth Tech Area 1 08-19-2017 11:14 AM
Do I Need A High Torque Starter BLACKHAWK Troubleshooting for Road Glides 5 05-25-2016 09:51 AM
Need Torque wrench suggestions redbaron Do-IT-Yourself 32 12-30-2014 05:51 PM
Need help with torque specs please Evolutionscc *General Road Glide Discussions/Pictures 3 04-04-2013 08:53 PM
Rear Shock Torque Value TracknTail Tech Area 2 08-11-2011 11:45 AM
