Handlebar Clamp Pin - Road Glide Forums
post #1 of 6 (permalink) Old 12-11-2017, 09:37 PM Thread Starter
Bobinator's Avatar
Handlebar Clamp Pin
Greetings
Any insight would be great.
Bought and installed F47 10" Signature bars for my '16 RGS. The bars themselves have a slot in them which allows me to rotate the bars toward me or away from me. The install went well, however I have a slight problem. When I position my bars (actually, in parallel with my forks, see pic) my hand grip switches are pointed down to much. When I try to rotate them up, I'm stopped by the pin on the handlebar switch clamps. The bars do have a hole, but to grind that hole into a slot would be a bit much for me, plus the cables are in the bars and don't like the idea of pulling the cables out again. That leaves grinding the pin off? (Finally the damn question) Has anyone else had this issue and how did you resolve it.
Thx for any and all help.
Bobinator
Last edited by Bobinator; 12-11-2017 at 09:42 PM. Reason: added the word switch for clarity
Bobinator is offline
post #2 of 6 (permalink) Old 12-11-2017, 09:51 PM
I donít have the same bars, but I did grind the pins off both sides to get the controls where I want them. I havenít had any problems with the controls shifting.
post #3 of 6 (permalink) Old 12-12-2017, 09:49 AM
bucketlisthd's Avatar
Those pins break off clean and easy. Use a screwdriver as a standoff and hit it with a hammer. Done.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #4 of 6 (permalink) Old 12-12-2017, 10:23 AM
I ground mine off. But with all the people that snap them off, I'd do that next time.
Buzzy is offline
post #5 of 6 (permalink) Old 12-12-2017, 02:14 PM
wevsspot's Avatar
Exactly
Properly re-torque the switch housing clamp screws and you're all set. The assembly won't move (even with the pins removed) as long as everything is snugged and tightened up properly. Mine have been that way for two years now.
wevsspot is offline
post #6 of 6 (permalink) Old 12-13-2017, 08:00 AM Thread Starter
Bobinator's Avatar
Thank you...thank you all.
This is such a great resource. Going to snap mine off.
Do appreciate the input.
Bobinator
Lost the Darn Handlebar Locating Pin rrcrum Controls & Handlebars 12 03-24-2016 01:04 PM
1 piece handlebar clamp Jwasielczyk Parts for Sale 0 12-19-2014 07:15 AM
Handlebar Clamp Removal jimmyray11349 Do-IT-Yourself 1 07-18-2013 05:30 AM
Single piece handlebar clamp roadglide-rider Controls & Handlebars 3 03-28-2013 09:47 AM
Muffler Clamp buzzman_45011 Intake and Exhaust 5 06-09-2010 04:15 PM
