Replacing Brake line with ABS - Road Glide Forums
post #1 of 4 (permalink) Old 05-07-2013, 04:18 PM Thread Starter
What does it take to extend the brake lines when doing a bar swap? I did not see a guide posted. I have ABS brakes. Local stealer said I need to order 3 brake cables, quoted me over 400 for the cables alone, I didn't even bother asking what it costs to install them.
I'd be looking at going +2 or +4 max.
ksarauer is offline
post #2 of 4 (permalink) Old 05-07-2013, 05:58 PM
To replace the bars, you really just need to change the upper line from the ABS module to the front master cylinder. Be careful here as many after market lines come as a two part line "upper and mid". Its not a big deal. Sounds like the dealer was trying to sell you the upper and lowers. If you're changing the line style and want them to all be the same, you'd have to buy them all. But if you just want to replace the upper line, you don't need to buy the lower line.
Don't buy the bull about the ABS having to be bled by the dealer. I did mine and have had no problems, no codes. Just bleed like any other.
The brake line is the easy side. The clutch cable is the pain in the shorts.
Cheers,
G
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Those white lines are just Road Chum ... and my Shark is HUNGRY!
2012FLTRU_BigBlue is offline
post #3 of 4 (permalink) Old 05-07-2013, 06:13 PM Thread Starter
They were trying to sell me uppers and lowers. I only care about the uppers. The clutch looks like the easy side. I'm surprised it would be more difficult than the brakes.
ksarauer is offline
post #4 of 4 (permalink) Old 05-07-2013, 06:22 PM
To replace the clutch cable you need to drain the transmission and remove the cover. To remove the cover, you need to remove the heat shields, the right footboard and entire exhaust. The bottom two bolts are obscured by the exhaust. Make sure you get all the gaskets (cover and 2 exhaust) and new O-ring.
Cheers,
G
12" Paul Yaffee Monkey Bars with Braided ABS Brake Line 1BadGlide Parts for Sale 0 01-25-2015 03:14 PM
Upper ABS brake line for 14" bars SMSgt B Controls & Handlebars 22 02-02-2013 10:28 PM
Replacing stock front upper brake line SickRick Controls & Handlebars 2 09-02-2011 06:24 PM
? longer abs brake line T-BO 399 Controls & Handlebars 4 11-15-2010 09:07 PM
Longer Brake Line for ABS Solution jakeblues Controls & Handlebars 0 03-05-2010 04:31 PM
