Hydraulic lines replacement - Road Glide Forums
post #1 of 16 (permalink) Old 12-23-2017, 08:21 PM Thread Starter
Speedy540's Avatar
Anyone have a video on replacing the brake and clutch lines on 15+ road glide? I did the cables and brake line on my 06 but I'm a little intimidated on this bike. With the splits and ABS
Speedy540 is offline
post #2 of 16 (permalink) Old 02-11-2018, 02:56 PM Thread Starter
Speedy540's Avatar
Anyone?
PIN IT TO WIN IT!
post #3 of 16 (permalink) Old 02-11-2018, 03:03 PM
No video for you. I replaced mine and wasn't that hard. Took it to dealer to get it bled out right. They do an ABS bleed through the computer.
Singlebeam is offline
post #4 of 16 (permalink) Old 02-11-2018, 03:06 PM
Brewiz's Avatar
No video but I did it on my 11 and its not that hard. I used a Mityvac to pull the new brake fluid thru the
lines from the brake reservoir to the calipers.
Brewiz is offline
post #5 of 16 (permalink) Old 02-11-2018, 06:56 PM
glide69's Avatar
Hill Country Customs has a Video on there site. They push the fluid/air up from the bleeder to the master cylinder.. No dealer needed!!
2018 FLTRXS Wicked Red
glide69 is offline
post #6 of 16 (permalink) Old 02-11-2018, 07:06 PM
I have done that. If you have ABS, you need to bleed the brakes then let dealer do an ABS bleed.
ChromeSpark likes this.
post #7 of 16 (permalink) Old 02-11-2018, 10:36 PM Thread Starter
Speedy540's Avatar
This is what I was thinking. I'm installing a FM 107 and heads at the moment so I'd like to change the lines out while it's all apart. I have to take it in to Dyno when I'm done so figure I'll just have them bleed them while it's there
PIN IT TO WIN IT!
post #8 of 16 (permalink) Old 02-12-2018, 05:53 AM
eddienelson's Avatar
Im gonna need a full report on that FM 107 on my desk by 8am. No seriously been looking at the 107 myself. What cam and compression are you going with?
2016 RG Custom Vivid Black
eddienelson is offline
post #9 of 16 (permalink) Old 02-12-2018, 09:12 AM
glide69's Avatar
That's what the Stealer want's you to believe...
glide69 is offline
post #10 of 16 (permalink) Old 02-12-2018, 09:22 AM
Well you're wrong . Trust me I know how to bleed brakes. After bleeding the abs brakes, still not stopping proper. Let dealer do a bleed through their computer/digital tech brakes now work the way they should. Thank you for your irrelevant information. BTW the abs bleed is not an actual brake bleed like one would imagine.
Sent from my XT1575 using Tapatalk
Replacement levers for hydraulic clutch Sethjamto Controls & Handlebars 10 10-29-2014 02:11 PM
Hydraulic Clutch throwing trouble code 69 A-body Controls & Handlebars 3 08-29-2011 08:10 PM
Extended Hydraulic Lines aclass Controls & Handlebars 4 02-12-2011 08:17 AM
Hydraulic Clutch DonL Controls & Handlebars 6 01-24-2011 08:24 PM
New pipes w/ hydraulic clutch? Pokerstar Intake and Exhaust 0 12-25-2010 10:25 PM
