Another clutch neutral switch issue. - Road Glide Forums
post #1 of 3 (permalink) Old 02-22-2018, 08:44 AM Thread Starter
It's a known fact the Harley's have issues with the neutral switch on the clutch reservoir which I'm having replaced tomorrow at the dealership.
This morning it wouldn't start in gear again, but this time I noticed something a little different. If the bike is running and you turn off the bike with the stop/start switch, leave the ignition switch on, it won't start when the clutch is pulled in. But if you cycle the ignition switch, pull the clutch in and then try to start it in gear it will start.
Anyone else seen this?
Geezer_Glide is offline
post #2 of 3 (permalink) Old 02-22-2018, 10:26 AM
BlazingSaddle's Avatar
Nope, but then don’t know I’ve actually followed that sequence of events. Gonna have to give it a try when I have access to my bike.
edit: pulled in clutch, dropped her in first, turned kill switch on, turned ignition on, hit the start, started right up. Hit the kill switch, left ignition on, released and pulled in clutch, turned kill switch on, hit start, started right up.
It ain’t me, so must be you. They’ll get her fixed up for ya.
BlazingSaddle is offline
post #3 of 3 (permalink) Old 02-27-2018, 09:33 PM Thread Starter
Mine seems to be working as you described after the dealership replaced the switch, I hope it holds upland doesn't give me anymore trouble.
Another clutch neutral switch issue Geezer_Glide Tech Area 2 05-23-2018 05:24 PM
2015 Clutch trigger / neutral safety switch Steelerdude1 *General Road Glide Discussions/Pictures 7 04-14-2016 07:54 PM
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 07:18 AM
New Issue with Neutral after Clutch Adjustment kevanbo Troubleshooting for Road Glides 16 06-20-2014 09:56 AM
clutch lever travel and finding Neutral Spock Troubleshooting for Road Glides 5 09-13-2013 06:32 PM
