cruise switch - Road Glide Forums
 5Likes
  • 4 Post By Big_gary
  • 1 Post By CPY84
post #1 of 7 (permalink) Old 03-06-2018, 07:18 AM Thread Starter
Unhappy cruise switch
I install the new factory 47 12" bars on my 2015 RoadGlide special and the left side switches didnt work. Found out that when i repluged everything back up i had turned the plug backwards. So i unpluged it and turn it over now most everything works except that i can turn the cruise on but it wont do anything else cant set or anything. Does anyone know if i screwed something up by having the plug backwards??
steelman18 is offline
post #2 of 7 (permalink) Old 03-06-2018, 07:43 AM
Check to see if your brake lights stuck on. If you didn't shim the brake hand lever open ,you might of broke the knub off the brake switch. If the computer thinks the brakes on, it won't let the CC come on.
Wood, madmat, BlueBagger12 and 1 others like this.
post #3 of 7 (permalink) Old 03-07-2018, 12:25 PM Thread Starter
Got home and sure enough the brake lights were on going to check them over on the weekend.
thanks i had forgotten all about that
post #4 of 7 (permalink) Old 03-07-2018, 12:49 PM
wevsspot's Avatar
Ouch, hope that you didn't break the plastic nub. Pretty sure that requires replacement of the entire switch pack.
wevsspot is offline
post #5 of 7 (permalink) Old 03-07-2018, 01:35 PM
WTFranz's Avatar
Just had mine replaced under warr. My trip button stopped working and the clutch switch failed intermittently.
The switch pack is only $220 so no big deal.
Mazikeen - 2016 Road Glide Special from Arizona
WTFranz is offline
post #6 of 7 (permalink) Old 03-07-2018, 01:46 PM
if that nub is broken ,go get some weld putty at walmart or auotparts and do it yourself. nobody will ever know.
Big_gary likes this.
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #7 of 7 (permalink) Old 03-07-2018, 03:21 PM
What he said ^^^ . Gorella glue works too. Take the housing apart slowly,so the knub don't get launched.
Road Glide Cruise Switch assembly georgec Parts for Sale 0 05-04-2015 09:41 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
Hard wiring the Cruise Control/Second Accessory Switch MotDab Do-IT-Yourself 8 09-03-2013 11:33 PM
Moving Cruise Control Switch CSM11 *General Road Glide Discussions/Pictures 13 08-23-2013 12:23 PM
Broke cruise control switch FLboi85 Do-IT-Yourself 2 02-10-2013 11:14 PM
