Left Side Clearance Issue- Floor Boards/Mount - Road Glide Forums
 2Likes
post #1 of 14 (permalink) Old 04-15-2018, 06:32 PM Thread Starter
2017 RGS. I have been practicing the low speed motor officer exercises and have had a couple of instances where I scrape on left hand u-turns. I assumed I was scraping the floor boards but noticed it seemed kinda harsh, so i checked and discovered I am actually scraping the floor board rearmost mount and not the edge of the floor board itself. I am kinda startled since the floor board mount is hard metal and could possibly lever the wheels off the ground. Can anyone else confirm this is happening on their rides and whether I should be concerned?
nelsonlwn is offline
post #2 of 14 (permalink) Old 04-15-2018, 07:06 PM
Learn not to scrape it. It's a bagger after all.
post #3 of 14 (permalink) Old 04-15-2018, 07:29 PM
rydin2's Avatar
Can't say it's never happened to me... I take it as a reminder to counter balance better. Keep the bike more upright with me leaning more... or just slow the hell down. Since you are doing precision drills in the parking lot try the counter balancing....
Acmegamer likes this.
rydin2 is offline
post #4 of 14 (permalink) Old 04-16-2018, 05:30 PM
ChromeSpark's Avatar
That is where the scrape marks are here. Advise......don't do that!
"It's a motorcycle, it´s not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #5 of 14 (permalink) Old 04-16-2018, 05:53 PM
I'll have to look on mine and see where I have scraped, however I too have had the same issue with left turns. I've scraped a few times now and it's been turning into parking lots or basically pulling into drives where you have to almost do a u-turn to pull in. I have never felt as though I've been pushing the bike too far or had any issues with stability, however that left turn likes to scrape much more than the right side!!!
Well, I just checked.... I scrape the rearmost portion of the left floorboard. After looking hard at the floorboard mount, you'd be hard pressed to drag that unless you're going over curbs etc and almost scraping the frame of the bike. Do you have different floorboard mounts? Mine are literally tucked right along the frame of the bike and it would be nearly impossible to scrape that mount before scraping the actual board.
Good luck and let us know!!!!
RoadglideinMO is offline
post #6 of 14 (permalink) Old 04-16-2018, 07:08 PM
Thermodyne's Avatar
I wore the sides out of a set of boards on my TRX, taller shocks cured it.
Thermodyne is offline
post #7 of 14 (permalink) Old 04-16-2018, 09:00 PM Thread Starter
Stock Floor Boards. No changes whatsoever. I checked again and there is no evidence of scraping the floorboard and the part of the rear most floor board mount that is parallel with the frame is definitely worn down from scraping. Weird as I assumed the boards would scrape before any other part of the bike.
post #8 of 14 (permalink) Old 04-16-2018, 09:03 PM Thread Starter
To clarify, are you saying your scrape marks are on the floor board mount vice the edge of the floor boards?
post #9 of 14 (permalink) Old 04-16-2018, 09:05 PM
eddienelson's Avatar
Put knee pads on and that way you can push before you scrape...
2016 RG Custom Vivid Black
eddienelson is offline
post #10 of 14 (permalink) Old 04-16-2018, 10:52 PM
I’m a former motor officer and I scrape the brackets all the time. It’s normal; I don’t worry about it. If you scrape enough you’ll wear a flat spot into the bracket. It takes a fair amount of scraping before they have to be replaced, but they’re easy to replace and cost only about $30 each. So I say good for you and keep practicing. It is possible to lever the rear wheel, but that’s unlikely during very low speed manuvers. The bike tends to fall over at low speeds before it levers. Levering at highway speed in a curve is a different matter. The rear wheel can lever if you don’t know where the limit is in that instance.
Stoic Joker likes this.
PeteF is offline
Right side 7.25 left side 5.25... Trak350 Audio 3 06-09-2014 10:28 PM
Ness Mini Apes master cylinder clearance issue any suggestions? SlowGuy Controls & Handlebars 1 01-13-2014 07:39 PM
Shock Mount / Muffler clearance tbone1957 Suspensions 3 03-28-2013 10:23 AM
back side of passenger floor boards toysrus Do-IT-Yourself 2 04-19-2011 07:04 AM
Yaffe Banana Floor Boards Freaky *General Road Glide Discussions/Pictures 13 02-19-2011 07:59 AM
