Check engine light with p0577 code tripped help needed - Road Glide Forums
post #1 of 18 (permalink) Old 06-02-2013, 02:20 PM Thread Starter
neuropac's Avatar
Bike has been running great except blowing taillights 2 in the last week, 200 miles into a ride Friday the check engine light came on and the cruise quit working no other problems. Checked the code and found p0577 cruise control input high. Finished the ride another 150 miles without any issues seems to running fine. Did the drop down test for the cruise without identifying the problem not sure where to go next. Prefer to repair it myself if I can no longer under warranty. Thanks Chris
2011 FLTRX 103
2005 Big Dog Ridgeback
1982 FXR Superglide 1340 shovel
neuropac is offline
post #2 of 18 (permalink) Old 06-02-2013, 02:42 PM
Gray Beard
lundboy1's Avatar
Here's the code
www.fuelmotousa.com/site/harleycodes.html
Harley Trouble codes. ... 81. P0577 Cruise Control Input High Priority/DTC/Fault condition HFSM = Hands Free Security Module TSM = Turn signal module 1.
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #3 of 18 (permalink) Old 06-02-2013, 04:13 PM Thread Starter
neuropac's Avatar
Lundboy1 thanks, I had seen this before, while researching the code and I also found info on doing the diagnostic drop down test of the cruise to check the sensors but so far everything check out fine. I cleared the code but after a few miles of riding the light returns and the cruise still doesn't work, I even did a hard reset by disconnecting the power by removing the 40 amp fuse no luck.
2011 FLTRX 103
neuropac is offline
post #4 of 18 (permalink) Old 06-02-2013, 06:23 PM
Gray Beard
lundboy1's Avatar
Well that sucks I wish it were that simple .... Any mods , work , or hard hits the bike has had lately?
lundboy1 is offline
post #5 of 18 (permalink) Old 06-02-2013, 06:50 PM
HellInABucket's Avatar
Last year I had a '12 Road King, on the way to Sturgis my cruise quit and the check engine light came on - not sure what the codes were but it was a bad cruise switch, Mankato HD swapped it out and I was good to go.
2018 FLTRU
Roll away the dew...
HellInABucket is offline
post #6 of 18 (permalink) Old 06-02-2013, 07:14 PM Thread Starter
neuropac's Avatar
Lundboy1 last big mods was over the winter with new bars and new gauges, install was straight forward without problems and no other electrical problems so far over 1500 miles since install. I continue to wander if the problem with the taillights is related.
Hellinabucket I wandered about the switch given all that has been reported on the forums about failure but from what I have read the cruise drop out test is suppose to identify a switch failure or sensor problem but if passed I performed it 4 times. Any other thoughts?
2011 FLTRX 103
neuropac is offline
post #7 of 18 (permalink) Old 06-02-2013, 08:15 PM
Blowing the fuse on the taillights and the cruise control not functioning may be related. You may have a short or a overload somewhere in the taillight system. Try to isolate the problem, start with pulling the rear light bulbs and if the fuse still blows then unplug the rear lighting harness, you may have a pinched wire under the seat or under the fender which is more common with bikes that have been lowered. It is hard to diagnose electrical problems some times with out the right equipment so taking it for repairs may be a better option if you cant find a obvious problem.
post #8 of 18 (permalink) Old 06-05-2013, 09:47 PM Thread Starter
neuropac's Avatar
Problem solved, the cruise set/resume switch was bad, replaced switch and no problems after a 40 mile ride this evening. I initially thought the switch was good but i was misinterpreting the drop down test. I am not sure what caused the premature failure of my taillight bulbs but I didn't find a ground. It may be time to replace the 11/57 bulbs with LEDs. Thanks to the members that responded for my call for help. I am not sure if the cruise and taillight failure is related.
2011 FLTRX 103
neuropac is offline
post #9 of 18 (permalink) Old 06-05-2013, 09:49 PM Thread Starter
neuropac's Avatar
Ironmark it has been blowing the bulbs not the fuse. Thanks for your help and info from other posts of yours on how to check the codes and interpret them.
2011 FLTRX 103
neuropac is offline
post #10 of 18 (permalink) Old 06-05-2013, 10:29 PM
Glad you found the problem and it was a easy fix.
Error code question or at least I think it's an error code wvdave Troubleshooting for Road Glides 1 07-15-2015 10:21 AM
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 03:59 PM
P0577 Cruise Control Input High Priority Illiniroads Troubleshooting for Road Glides 1 07-02-2013 09:10 PM
P0577 windup Troubleshooting for Road Glides 6 12-04-2012 03:45 PM
need Help Check Engine light issue jprider4life Troubleshooting for Road Glides 4 06-01-2012 04:11 PM
