Handlebar Wiring - Road Glide Forums
post #1 of 14 (permalink) Old 12-12-2010, 06:15 PM Thread Starter
Martin's Avatar
Location: So. Cal native currently in the Battle Born State of Nevada
Handlebar Wiring
In a number of the threads I have seen that RG owners have put on taller bars using the stock cables. If I remember correctly up to 10" to 12". I have checked my local dealers and found that they advise that the stock cables wont go that high. They estimate 1" to 2" from stock. Are they full of it? I just got an 11 RG and am interested in going higher (I am 6-4). Any help is appreciated.
2011 FLTRX Vivid Black
Veritas et Aequitas
Martin is offline
post #2 of 14 (permalink) Old 12-12-2010, 06:43 PM
CHAINSAW's Avatar
Totally full of it,. Im running 15" apes with stock cables, just rerouted them. Your dealer is trying to squeeze you for all he can.
Such is the rule of honor.
CHAINSAW is offline
post #3 of 14 (permalink) Old 12-12-2010, 09:37 PM Thread Starter
Martin's Avatar
Very good Chainsaw; you have confirmed my BS meter. I will keep working at it.
Veritas et Aequitas
Martin is offline
post #4 of 14 (permalink) Old 12-12-2010, 11:17 PM
Ducflames904's Avatar
Martin, stock wires will make it but brake and clutch will not over 12". I have 12" wild1's and am maxed on B&C cable. Plenty of wire left over though. Maybe Chainsaw can confirm this.
Ducflames904 is offline
post #5 of 14 (permalink) Old 12-13-2010, 10:08 AM
CHAINSAW's Avatar
Brake and clutch good for 15" apes on a 2010 ABS FLTRX. Its maxed out, but 15" is doable. I didn't change a thing except cut zipties on the brake line, and reroute the clutch cable behind the frame and behind the triple tree.
CHAINSAW is offline
post #6 of 14 (permalink) Old 12-13-2010, 07:02 PM
Talking Chainsaw is right
I just did my 12" monkey bars, I cut the zip tie and took the clutch cable from between the forks to the outside. Yes it flops on the nuts, but (well I won't go there) there is plenty room. Check out my picks I posted earlier, as for the brake line it is better where it is than where it was prior. I even put a slight twist so it runs closer to the bars, and stays with no ties.
Frodoe is offline
post #7 of 14 (permalink) Old 12-13-2010, 08:00 PM
Peewee's Avatar
+1, I just did 12" bars on mine without any cable change or wire extensions. Just a re-route. Pics of the bars on are in this section thread title is: "my new bars" I was a doubting thomas at first, but I can say that I was wrong. 12"s are no problem
"Know Thyself"
Peewee is offline
post #8 of 14 (permalink) Old 12-14-2010, 08:33 AM
DED HD's Avatar
I put 14" Santees and only changed the clutch cable(+4")so it could route in the same location as stock.
'10 Red Custom:
DED HD is offline
post #9 of 14 (permalink) Old 12-14-2010, 09:47 AM Thread Starter
Martin's Avatar
Thanks all! Expecting snow here for the next week so I think its time to order and install.
Thanks again!
Veritas et Aequitas
Martin is offline
post #10 of 14 (permalink) Old 12-14-2010, 12:39 PM
jimmyo79's Avatar
Thanks for confirming my same exact inquiry! You guys Rock the RG Knowledge!!
Jimmy O.
100th Anniversary Glide
No Ride like a Low Ride Glide!!
jimmyo79 is offline
Wiring Suggestions for Handlebar Change mrauenzahn Controls & Handlebars 1 01-21-2015 06:47 PM
Handlebar wiring harness rdrnr03 Parts for Sale 0 04-18-2014 05:36 PM
Handlebar Ignorant/ Wiring Pork Chop Controls & Handlebars 10 03-04-2014 01:10 PM
internal handlebar wiring col flagg *General Road Glide Discussions/Pictures 33 02-24-2014 06:50 PM
Tour Pak w/CB/Speakers/Liner/wiring/handlebar control jrbean1 Parts for Sale 5 06-19-2013 10:48 PM
