Swapping bars - Road Glide Forums
post #1 of 4 (permalink) Old 06-05-2013, 08:23 PM Thread Starter
Swapping bars
Ok I am going to be tackling swapping my bars over to WO612 here shortly and have a few questions. I was reading about a spacer you need to put in the brake leveler to not break something, is this true?
Also can I just swap without any additional parts on a 13? I have been told the wires are long enough but others have said to swap the TBW. Is there any reason I can't leave the green plug in the bars like it comes stock? I like to not have to swap to much extra stuff. I do have heated grips on the bike already too.
Thanks
SnowBandit
SnowBandit is offline
post #2 of 4 (permalink) Old 06-05-2013, 09:00 PM
93-331-29psi's Avatar
The manual states you should put a spacer (matchbook seems common) between the lever and the brake switch but I've never done it and never had issues.
Sent from Motorcycle.com App
93-331-29psi is offline
post #3 of 4 (permalink) Old 06-05-2013, 09:18 PM
Yes shim the lever . It keeps you from breaking the tit off the brake light switch. If you don't shim it , just be very careful when re-installing and you'll be fine. Replace the tbw with the SE tbw because it eliminates the green connector.you could just cut the connector out and solder the wires together. Either way get rid of the green connector.
Not sure about if you need extended clutch or brake line but you'll have plenty of wire to work with.
post #4 of 4 (permalink) Old 06-05-2013, 09:20 PM
ammojeff's Avatar
Just did the WO612B 12" Black Outlawz myself last weekend. No problem with the brakes. Yes the existing wiring is long enough, the clutch cable may need to be rerouted some do some don't. Those lower mitered 90s on the bars will test you patience but the wires will go. There is a Sticky thread on here Posted by Donk and the instructions will get you through the process it helped me immensely even though I have done other bikes before, A RG is different beast for sure that's why we love em so much. Good Luck
AMMO: Giving the enemy the opportunity to die for their country
ammojeff is offline
Swapping out my 14" Yaffe bars for 16" SWThomas *General Road Glide Discussions/Pictures 3 01-06-2017 08:55 PM
? on Swapping Handle Bars 15 RoadGlide FLTRXS18 Controls & Handlebars 28 03-25-2015 08:25 AM
Anyone interested in swapping YOUR 12" Yaffes for MY 10"? RGCBandit Controls & Handlebars 3 05-21-2013 04:48 PM
Pros and cons to swapping out cartridge left fork... Nick-O Suspensions 6 01-05-2013 07:08 PM
Swapping out passengers pegs? Effenglide Road Glide Specific Discussions 2 07-05-2011 10:12 PM
