Stock controls with 12" Monkey bar? - Road Glide Forums
post #1 of 7 (permalink) Old 06-07-2013, 03:30 PM Thread Starter
I picked up a used set of 12"monkey bars, to good of a deal to pass! My question is can you use the stock length controls ie clutch, brake etc with them. I have heard you can, just want to definitive answers before I buy the extetnion kit. Thank all.
2010 FLTRX- Black Denim, Rev Tech Dominator 18's w/matching rotors, RSD grips, RSD air cleaner, Vance and Hines pro pipe, Power commander V, chopped wind screen.
Torkmnstr is offline
post #2 of 7 (permalink) Old 06-07-2013, 03:53 PM
Banned
I just installed the 12" Wild1 outlawz and didnt have to change out a single thing other than the brake cable washers so you should be ok. If u want some measurements let me know. ImageUploadedByMotorcycle1370638236.211046.jpgImageUploadedByMotorcycle1370638263.516643.jpg
"If the opposite of pro is con, then that means the opposite of progress is congress"
Scootin is offline
post #3 of 7 (permalink) Old 06-07-2013, 03:58 PM Thread Starter
Did you have to reroute our clutch line? As for the front break line it fits fine?
post #4 of 7 (permalink) Old 06-08-2013, 12:20 AM
Bandit's Avatar
You will have to re-route the Clutch Cable / Hose, but they will fit.
2005 FLTR - 97" S&S Big Bore, Hillside Cycle Stage II Heads & Throttle Body Upgrades, S&S Rollers, Fueling Pump & Lifters, 570G Gear Drive, TTS, CFR's, Klock Werks Double Back, 104hp/106ftlbs. CB's Euro, PM Light Glide LED Kit, RC CZar Wheels
Bandit is offline
post #5 of 7 (permalink) Old 06-08-2013, 12:35 AM
if these are yaffe bars you will need different cables, I went with 10" and still had to reroute the clutch cable, baggernation.com call and confirm for sure tho. Not to burst your bubble but running your wires internally was a pita, but well worth it
2012 Crome Yellow,10" Bagger Nation monkey bars
V and H Pro pipe, Fuelpak, Throttlepak
S/E Heavy Breather, CVO windscreen
jstucker1976 is offline
post #6 of 7 (permalink) Old 06-11-2013, 07:22 AM
OKBigD's Avatar
Stock Cables
I just installed a set of 12" Buky Bars, very similar to the PYO Monkey Bars and had plenty of room on clutch, brake, and stock controls..... All I did on the clutch was move it in front of the triple tree instead of behind it.... Still looks good.
By the way, buy a molex removal tool, much easier than taking the connector apart... Just pull up on the white part inside the connector housing until it clicks, Then insert the needle end into the small hole in the white part inside and pull on the back of the wire, and out comes the terminal......... Super easy.. There is no reason to cut and splice IMO.....
http://www.ebay.com/itm/Generic-Harl...item3a6a50733a
OKBigD is offline
post #7 of 7 (permalink) Old 06-17-2013, 11:38 PM Thread Starter
Thanks all. I broke down and got the la choppers extension kit. I want to keep it all in the stick arrangement.
Handle bar chart for 2015 stock controls ynotbmester Controls & Handlebars 2 07-03-2015 06:22 AM
It is now 12:12 12-12-12!!! Garemlin General Off-Topic Discussions 10 12-12-2012 09:45 PM
12" Monkey Bars with 12" WindVest Shield? Tek74 Controls & Handlebars 3 02-13-2012 07:50 PM
10" or 12" OEM Monkey Bars for someone 5'5" bagger68 Controls & Handlebars 7 01-09-2012 12:05 PM
