should i pull maxi fuse before bar install? - Road Glide Forums
 4Likes
  • 4 Post By wevsspot
post #1 of 9 (permalink) Old 06-04-2018, 07:41 PM Thread Starter
Jersey Drew's Avatar
is it necessary to kill power to the bike before unplugging everything?
'16 Road Glide Special
Jersey Drew is offline
post #2 of 9 (permalink) Old 06-04-2018, 07:52 PM
wevsspot's Avatar
Yes.
You'll need to pull your instrument nacelle (speedo, tach etc.) and it's always a good preventative measure to pull the main fuse before you go unplugging or plugging wires and connectors. You'll thank us later.
madmat, Swomack, RFG7680 and 1 others like this.
wevsspot is offline
post #3 of 9 (permalink) Old 06-04-2018, 08:03 PM
RFG7680's Avatar
Originally Posted by wevsspot View Post
Yes.
What him say.
RFG7680 is offline
post #4 of 9 (permalink) Old 06-04-2018, 08:04 PM
skratch's Avatar
and if you have a siren installed, don't just go pulling the fuse. even if you don't, it's still a good idea to disarm your security first. with fob in hand, turn your ignition on, let the security disable, and then turn off your ignition. now, you've got about 3 seconds to pull your maxi fuse before the alarm enables again.
skratch is offline
post #5 of 9 (permalink) Old 06-04-2018, 08:09 PM Thread Starter
sounds good. on the '16 is it still under the left panel?
post #6 of 9 (permalink) Old 06-04-2018, 08:10 PM
madmat's Avatar
What they say!
I am as lazy as the day is long but, for the 2 minutes it takes its good mojo.
18 RGS Bonneville Salt Pearl
madmat is offline
post #7 of 9 (permalink) Old 06-05-2018, 08:42 AM
wevsspot's Avatar
Yes. 50A fuse under the left side cover. Red in color. You can't miss it.
wevsspot is offline
post #8 of 9 (permalink) Old 06-05-2018, 09:52 AM
sfcusaret2004's Avatar
Per the service manual, turn the ignition to on, remove main fuse, turn ignition to off. Commence work!
sfcusaret2004 is offline
post #9 of 9 (permalink) Old 06-05-2018, 12:10 PM
BB Bomber's Avatar
Didn't even think to pull the fusewhen I swapped mine out. Guess I got lucky.
BB Bomber is offline
Questions about 14'' Santee apes, before I pull the trigger Robgrover Controls & Handlebars 5 04-30-2015 01:10 PM
Handle Bar Pull Back ? FLTRXS18 Controls & Handlebars 2 03-26-2015 05:46 AM
What is maxi fuse? mhud3780 *General Road Glide Discussions/Pictures 5 03-30-2013 01:58 PM
Should I pull the Trigger nightrider069 Engine Related 6 11-04-2012 07:16 PM
Should I or should I not Runto77 Aftermarket Accessories 2 09-10-2010 06:04 AM
