so this weekend is my install.. - Road Glide Forums
 3Likes
  • 2 Post By BobRG15
  • 1 Post By TLKurtz
post #1 of 7 (permalink) Old 06-29-2018, 07:11 PM Thread Starter
Jersey Drew's Avatar
after two weeks of waiting for the bars and my bike being in the shop for 3 weeks for a new trans, i finally have the bike and bars at my house at the same time. this weekend is supposed to be well over 100 and i have things to do where i need my truck so this weekend is the time to take the plunge!
any last minute advise/tips/tricks on the bar install?
'16 Road Glide Special
Jersey Drew is offline
post #2 of 7 (permalink) Old 06-29-2018, 08:02 PM
BobRG15's Avatar
Patience grasshopper
TLKurtz and madmat like this.
Mako Fade Shark added Tour Pak with pass backrest-drivers backrest-pass floorboards-saddle bag guards
BobRG15 is offline
post #3 of 7 (permalink) Old 06-30-2018, 10:32 PM
I installed a set of Invicta's last week. Yup, have patience. Also a tip when it comes to the throttle side since your pulling 2 harnesses thru there. I first pulled the throttle wire down and with the control stalk harness, I disconnected it from the stalk (those 2 little plugs) and pull them up from the bottom. I tried pulling it down but the TBW harness just wouldn't allow it some reason.
2018 CVO RG Stage III
2017 Road King Special Stage IV
*Tilting MotorWorks Converted*
Wheelz is offline
post #4 of 7 (permalink) Old 06-30-2018, 11:01 PM
guerra's Avatar
Good luck. My install made me cuss and drink beer!
guerra is offline
post #5 of 7 (permalink) Old 06-30-2018, 11:40 PM
TLKurtz's Avatar
Send a message via Skype™ to TLKurtz
I've now done a Wide Glide and 4 Road Glides. Take your time, cover the painted parts, turn on some relaxing music, and realize that these parts are all made to work together. If you are relaxed during the install it's a breeze, and can actually be fun (if you enjoy wrenching). Good luck.
Swomack likes this.
-TLKurtz (Mr. Wizard) - Blackhorse Cavalry Nomads VMG member (2/11 CAV - East/West German Border)
2015 RGS - Vivid Black and loads of fun.
Reside in Vegas. I keep cold beer in the fridge for all visitors.
TLKurtz is offline
post #6 of 7 (permalink) Old 07-01-2018, 03:52 PM Thread Starter
so my laziness and world cup got the better of me today. so looks like i put it off once again...
post #7 of 7 (permalink) Old 08-18-2018, 05:21 PM Thread Starter
the bars finally went on today! the install was ok took a total of 3ish hours with the most time being running the TBW and installation. i had to take things apart 2 and 3 times do to ignorance. i had to remove the bars a second time to cut the zip ties and i had to remove the lever housings cause i ran the cables over the bars instead of behind.
as far as the install i would say that next time can be much faster and easier. with my '16 i did not have to remove the connectors and i did not have the infamous green connector in my TBW.
the bars themselves are beautiful but the 12s i ordered are still a bit short, i should have gone 14 or even 16 inch. they are also quite wide which will take some getting used to.
Metzler 888--so far, so good StriderJim Wheels and Tires 46 02-26-2016 08:05 PM
So, so close - need plate help Methos1979 *General Road Glide Discussions/Pictures 39 01-22-2016 07:58 PM
So ive made up my mind or should i say 95% of my mind........ maddmoe *General Road Glide Discussions/Pictures 12 08-29-2014 02:48 PM
So Cal Weekend Rides 63 340hp Organize Rides Here 12 03-26-2011 02:09 PM
