Handle Bars with more pull back ? - Road Glide Forums
 3Likes
post #1 of 15 (permalink) Old 07-11-2018, 08:30 PM Thread Starter
mikebrls's Avatar
So I am vertically challenged " also short arm's " and I'm looking for bar's that would be the same height as stock but with 2 to 4 inches of pull back so i can lean back more when riding " 2018 RG "
if you can post a link that would be great
Thank you
Mike
mikebrls is offline
post #2 of 15 (permalink) Old 07-12-2018, 01:50 AM
Unless you are looking for an EXTREME pull back... you really should be fine with most any aftermarket bar stock height or otherwise, you can roll most of them forward or back at LEAST to inline with the forks (which even for shorter guys I would think is plenty), especially if the grip angle is sloped a little it will seem closer to you.
I went F47 and they are dope. Also looked at Carlini, love those too, and BR customs as well.
No links, but there's some options for ya.
Goodluck!
Brit
mikebrls likes this.
BRIT206 is offline
post #3 of 15 (permalink) Old 07-12-2018, 08:34 AM
wevsspot's Avatar
Mike, you might consider contacting Jim Rundle at JSR Custom Choppers;
JSR Customs
Tell him your height, wingspan and what you're looking for. He can build you a set of 12" bars in a couple of different styles that would probably get you what you're looking for. His craftsmanship is top notch and prices are very very reasonable.
wevsspot is offline
post #4 of 15 (permalink) Old 09-03-2018, 12:01 AM
Cruisin1966's Avatar
I'm gonna give Jim at JSR a call to build me a Bad Attitude style bar. But before I do, I could use some help rounding up the dimensions of the stock 2018 RG CVO handlebars for comparison. I'd like another inch or so of pullback (without having to roll the bars too far back), and more flare (outward) to the grips and something between 12 and 14" of rise. I"ll try to get a little help taking measurements in the morning.
2018 Black Earth/Vivid Black CVO Road Glide
1999 Deep Turquoise/Ancient White Heritage Springer
Cruisin1966 is offline
post #5 of 15 (permalink) Old 09-03-2018, 04:32 AM
texasnurse's Avatar
texasnurse is offline
post #6 of 15 (permalink) Old 09-03-2018, 06:59 AM
geo8866's Avatar
Check out Klockwerks Klip hangers. The smaller ones are about the height of stock bars but the grips are adjustable.
geo8866 is offline
post #7 of 15 (permalink) Old 09-03-2018, 09:31 AM
bosshogg123's Avatar
The 14” Kliphangers might do the trick for you
bosshogg123 is offline
post #8 of 15 (permalink) Old 09-03-2018, 10:45 AM
I have the 14" Kliphangers.
They were my 3rd try on aftermarket bars. I'm 100% pleased with them. The adjustable wrist angle is very nice.
bosshogg123 likes this.
2017 Hard Candy Hot Rod Red Flake M8 FLTRXS Road Glide Special. Stage III with *lots* of other goodies.
msquad is offline
post #9 of 15 (permalink) Old 09-03-2018, 10:49 AM
BubbaBeef's Avatar
Location: Northern Illinois, where the suburbs end and the corn fields begin
If your looking for apes, check out KST Kustoms. They will do custom bends, to give you more pull back. Great customer service too!
Panic, chaos, disorder, my work is done here.
BubbaBeef is offline
post #10 of 15 (permalink) Old 09-03-2018, 12:06 PM
Originally Posted by texasnurse View Post
Thanks, exactly what I was looking for
Thanks, I'll add these to the list. Looks like the Black/Black in 14" are on backorder. My initial take on them, is they may be a little busy looking.
Yes, anyone who can do custom can build me a set now that I have the dimensions I need.
I'm looking at 14" rise, 36" width and about 10 or 11" pullback. After that, it's all about the wrist angle.
Front brake handle hard to pull firewalker17 Do-IT-Yourself 2 03-20-2017 06:30 AM
harley pull back bars gsbuick65 Controls & Handlebars 1 03-22-2016 10:43 PM
Handle Bar Pull Back ? FLTRXS20 Controls & Handlebars 2 03-26-2015 06:46 AM
Need more pull back than Heritage Bars jacksonfdny Controls & Handlebars 22 05-23-2013 05:40 PM
Handle Bars Moved Back runnhrd Controls & Handlebars 19 10-22-2011 10:00 PM
