Ignition issues - Road Glide Forums
  • 1 Post By BH#103
post #1 of 7 (permalink) Old 08-02-2018, 09:39 PM Thread Starter
Ignition issues
09 Ultra Classic Electra Glide. Decided to change handle bars for a pair of 15's. Watched a few videos, only problem i had was taking the swicth out. Finally found that solution, pulled it, got everything changed out, used a flat head screw driver to unlock the forks, putting everything back together, switch seems to now have a mind of its own. It will turn in all positions, no power, nonstart. Finally got it to turn on, checked radio, lights, signals, all work, but wouldnt turn over. pulled switch back out, same results using a screw driver. finally found a point where power would come on, everything but start works, but couldnt turn it off with ignition or screw driver. Finally pulled main 40 amp fuse to kill the power.
suggestions?
CheyenneTrk is offline
post #2 of 7 (permalink) Old 08-03-2018, 08:03 AM
FDR's RGC's Avatar
Keep fucking with ignition switch till it's right. Harley has an alignment tool that you may be able to rent,borrow or ride to shop and have them align it.
FDR's RGC is offline
post #3 of 7 (permalink) Old 08-03-2018, 08:43 AM
Morningwood's Avatar
I had my ignition pop out twice while attempting to unlock the forks. HD had no explanation, just lubed the switch and replaced it. Both times the forks were left locked and I had to pay HD to bring out a tool to unlock the forks. I said screw it and bought the Jim's alignment tool. I have changed bars twice since then and just to test it, intentionally pulled the ignition incorrectly and re-installed in the wrong position. all functions were jacked up. Used the jims tool and everything went back together perfectly. Some people make their own, but I paid for something I know would get me out of a bind. The tool is always on the bike.
Morningwood is offline
post #4 of 7 (permalink) Old 08-03-2018, 11:23 AM
BH#103's Avatar
If you cannot get it realigned, pull the switch off and disassemble it to realign. Sometimes this is easier or at least it has been in my adventures. There is nothing difficult about it, if you can do bars you can reclock a switch. I do suggest to get or make a tool for this job and leave it in until the job is done that way it cuts down on the dicking around if the switch gets out of alignment. Good luck!
"SLIVER"
BH#103 is offline
post #5 of 7 (permalink) Old 08-03-2018, 03:05 PM
Mike U's Avatar
I went through the same dilemma a few years ago and found a cool tool through The Google.
I bought it and haven't had any issues since.
Was well worth the $25.00.
Here's a link. Harley Ignition Switch Tool
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #6 of 7 (permalink) Old 08-05-2018, 08:42 PM Thread Starter
Thanks everyone for the advice. Screwdriver option worked. That is one, seemingly EASY lock to pop off. Should I be concerned about theft issues? Seems like you could just pop one off and use a screw diver to start it.
post #7 of 7 (permalink) Old 08-06-2018, 05:28 AM
BH#103's Avatar
The lock should not just pop off easily. You need a barrel key with the same configuration as the lock in order to remove it from the switch. If yours is just coming off then I would recheck it as it's not in correctly.
Mike U likes this.
"SLIVER"
BH#103 is offline
Removing your ignition switch joke Do-IT-Yourself 21 01-05-2019 02:18 PM
Harley Ignition Tool (Homemade) joke Do-IT-Yourself 4 04-05-2012 09:13 PM
Chrome Ignition Switch Cover for Road/Glide cestaro Aftermarket Accessories 4 06-06-2011 05:17 AM
Harley Ignition tool (made by Jim's) RoadGlide0611 Troubleshooting for Road Glides 7 02-09-2011 07:38 AM
Ignition install please help!! raven006 Do-IT-Yourself 4 03-15-2010 02:47 PM
