Clutch cable leaking? - Road Glide Forums
 9Likes
post #1 of 11 (permalink) Old 08-08-2018, 07:17 AM Thread Starter
On my '13 FLTRXSE2, I've been noticing that when I grab the clutch lever after the bike has been sitting, especially when the outside temp is hot, I'm finding fluid on the lever. It's not enough to drip down or puddle on/under the bike but it does get on my hand/glove. I've been traveling down the road, felt the fluid on my hand and wiped it off on my jeans - looks clear on my hands, leaves a black 'stain' on the jeans.
I haven't gone too deep into troubleshooting yet but all bolts and screws are tight around the reservoir and clutch cable. All levels appear to be okay. At this point I'm not sure if the fluid is hydraulic (clutch), or brake fuild. Some quick Google'ing only brought up one other similar issue where the Tranny Breather was clogged which caused oil to bleed out through the clutch cable but that was a Sporty.
Anyone else run into this or something similar? Any suggestions on the next troubleshooting steps?
clsmith is offline
post #2 of 11 (permalink) Old 08-08-2018, 08:37 AM
RGKen's Avatar
Just to correct your terminology a bit, you don't have a clutch cable you have a hydraulic line as your clutch on your CVO is hydraulic and not a cable clutch. Also, the fluid used for a hydraulic clutch is DOT 4 brake fluid so it is the same stuff that goes into the brake master cylinder on the other side.
1.) There is a lubricant that is used to lubricate the clutch lever to help it operate correctly and help prevent wear. If you have your bike serviced regularly chances are the tech actually did lubricate your clutch lever, some don't, and they may have over done it a bit and that is what is running down the lever.
2.) It is very common for the clutch (or brake) reservoir cap rubber seal to wear out and leak down the side of the reservoir. You can usually tell this is the issue if the black paint on the cap is bubbling and flaking off. Check around that seal at the cap to see if it is wet. Some dealers replace the cap and seal when they do a flush and that is part of the cost for the service. I believe it is around $45 for a new cap and rubber seal but I could be wrong.
3.) There is a banjo bolt that connects the hydraulic line to the reservoir and it uses 2 brass crush washers, one on either side of the line fitting, and they could be leaking. If that is your issue you will have to remove the fluid, just like bleeding your brakes, and change those crush washers then re-bleed new fluid back into the line. The bleeder valve is down on the right side tranny cover.
If you have to do #3 there is a spec for the pressure plate so you don't get any drag on the clutch and you may have to bleed the line a few times to get it within the spec. The procedure is in the manual so I won't type that here.
Hope this helps and let us know what you find. Good luck.
2018 FLTRXS
RGKen is online now
post #3 of 11 (permalink) Old 08-08-2018, 09:58 AM Thread Starter
Originally Posted by RGKen View Post
Just to correct your terminology a bit, you don't have a clutch cable you have a hydraulic line as your clutch on your CVO is hydraulic and not a cable clutch...
Thanks for the clarification! I knew it was a hydraulic clutch, didn't know it wasn't a cable!
1.) There is a lubricant that is used to lubricate the clutch lever to help it operate correctly and help prevent wear...
That was my first thought. Seems to run a little "thin" for a grease. That being said, it's been happening for a while (since June). One would think it would stop at some point, right?
2.) It is very common for the clutch (or brake) reservoir cap rubber seal to wear out and leak down the side of the reservoir. You can usually tell this is the issue if the black paint on the cap is bubbling and flaking off...
Perfect, there's my next step. I 'thought' I noticed some gunk around the cap!
3.) There is a banjo bolt that connects the hydraulic line to the reservoir and it uses 2 brass crush washers, one on either side of the line fitting, and they could be leaking...
I'll check that as well. I definitely tightened the bolt that holds the banjo(s) but didn't check for the crush washers (though, it was dry).
All your suggestions definitely make sense. Can't thank you enough!
RGKen likes this.
clsmith is offline
post #4 of 11 (permalink) Old 08-08-2018, 10:04 AM
twowheeladdict's Avatar
If it is DOT 4 brake/clutch fluid, don't let it get on anything you value like paint, plastic, etc.
If you haven't had the brake and clutch fluids changed in a while, might be a good time to get that done and the issue fixed at the same time.
RGKen and geo8866 like this.
2018 Road Glide Special, 2018 Moto Guzzi V7III Carbon, 1975 KT250 Trials
twowheeladdict is offline
post #5 of 11 (permalink) Old 08-08-2018, 11:21 AM
RGKen's Avatar
It came with a grease from the factory but on the maintenance they use a needle oil pen and yes it should have stopped by now. My guess is that it's the rubber seal for the MC cap. Like TwoWheel stated, DOT 4 is very corrosive so don't let it sit on anything for very long and I second his advice on getting the brake fluid and clutch fluid flushed if it hasn't been done in 2 or more years. Very important for the ABS system function to not let the fluid get old and contaminated.
You're welcome!
Just let us know what the culprit ends up being so we can learn if it happens to be something new.
2018 FLTRXS
RGKen is online now
post #6 of 11 (permalink) Old 08-08-2018, 11:43 AM
geo8866's Avatar
I might be remember incorrectly but wasn't there recently a recall on hydraulic clutches and brakes? Actually, I think there was one recall related to the clutch lever and another related to flushing the fluids. i know I brought my 14 street glide in for a clutch recall but I don't think the clutch was hydraulic on that model. I have no idea if this is related to your issue but I figured I'd throw it out there in case it is something you can get done for free.
RGKen likes this.
geo8866 is offline
post #7 of 11 (permalink) Old 08-08-2018, 12:32 PM
RGKen's Avatar
Yes there was and that's great that you brought that up geo8866. He might be able to get this taken care of for FREE! Easy enough to check anyway.
Just enter your VIN in the below link and see what pops up
https://www.harley-davidson.com/us/e...e-recalls.html
Also check with your dealer.
geo8866 likes this.
2018 FLTRXS
RGKen is online now
post #8 of 11 (permalink) Old 08-08-2018, 01:14 PM Thread Starter
...Just enter your VIN in the below link and see what pops up...
The good and the bad - no open recalls.
clsmith is offline
post #9 of 11 (permalink) Old 08-15-2018, 07:12 AM Thread Starter
...yes it should have stopped by now. My guess is that it's the rubber seal for the MC cap...
Just a quick update: the MC cap is dry. I've been watching it closely and it's not coming from there. Seems to be from behind the lever or from the lever itself.
I'll let you know if/when I find something.
RGKen likes this.
clsmith is offline
post #10 of 11 (permalink) Old 08-15-2018, 10:03 AM
If it's not from tech lubing the lever or from the cap. It could be the seal on the plunger, in which case the clutch master cyclinder will need a rebuild.
Buzzy is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
leaking clutch resivour Spazeack *General Road Glide Discussions/Pictures 2 04-17-2016 09:38 PM
Braided Clutch Cable Repair? hdmagic Troubleshooting for Road Glides 1 08-15-2010 06:30 AM
Clutch cable clip on side of gauge housing GizmoGlide *General Road Glide Discussions/Pictures 8 03-26-2010 12:00 PM
