Tail light not working after new bars installed - Road Glide Forums
post #1 of 9 (permalink) Old 06-15-2013, 11:40 PM Thread Starter
Installed bars yesterday and today my running tail lap is not working. Brake light works. Where do I begin troubleshooting? Everything else appears to be working...
ksarauer is offline
post #2 of 9 (permalink) Old 06-15-2013, 11:43 PM
FlyByWire's Avatar
Fuse. Had the same thing happen. Blew the fuse due to a pinched wire from the front ambers upon re-install.
2013 Candy Orange - Cobra Duals, CFR's, SE Heavy Breather - 17" Carlini Evil Apes
FlyByWire is offline
post #3 of 9 (permalink) Old 06-15-2013, 11:55 PM Thread Starter
Yep, that was blown, and instantly blew the new one when turning ignition on....
Now the fun begins tracking down the issue...
ksarauer is offline
post #4 of 9 (permalink) Old 06-16-2013, 12:35 AM
FlyByWire's Avatar
Make sure the wires aren't pinched or exposed between the mount and the fairing
post #5 of 9 (permalink) Old 06-16-2013, 12:45 AM Thread Starter
From the schematic it looks like the wiring for the lights is from the clutch side (grey connector). I had a number of f'ups wiring the connector back together with that side. The sun was coming up, and I was very tired.
ksarauer is offline
post #6 of 9 (permalink) Old 06-16-2013, 11:21 AM Thread Starter
Checked for any pinched wires and found nothing.
Checked the connection wiring to see if there were any swapped and everything looks correct.
What do I do next?
ksarauer is offline
post #7 of 9 (permalink) Old 06-16-2013, 11:59 AM
I would start with a good supply of fuses, then unplug one side and see if the fuse still blows then the other , eliminate it one side at a time to isolate where you need to start looking for the trouble .
Eagle
Eagle is offline
post #8 of 9 (permalink) Old 06-16-2013, 01:26 PM Thread Starter
That's exactly what I did. Purchased a pack of 25 fuses. Replaced it and it's all working now... Guess I'll start putting it back together, checking periodically and see what happens...
ksarauer is offline
post #9 of 9 (permalink) Old 06-17-2013, 12:09 AM Thread Starter
Put it back together, checking periodically and all was good. I tightened the bolts on the fairing and put the headlights in (the were connected but not attached to the bike). Checked lights and the fuse was blown again...
It had nothing to do with the bars, I pinched the wires on the front left turn signal which caused the short.
Glad I found it, not happy with the hassle and the time I spent working on it today instead of riding!
ksarauer is offline
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 11:09 AM
Harley Ipod Interface not working after install. Cobal59 Audio 1 03-21-2017 02:42 PM
Engine Light on after new bars installed RADDBUS Controls & Handlebars 15 11-02-2013 10:35 PM
horn , signalsand brk light not working cyco sam Troubleshooting for Road Glides 5 08-23-2013 08:43 AM
Tail Lights (not working) Weekender1969 Road Glide Specific Discussions 2 12-11-2011 06:25 PM
