Cruise control not working again - Road Glide Forums
post #1 of 15 (permalink) Old 10-06-2018, 05:09 PM Thread Starter
had this same problem a while back and that cause was the accessory fuse blown. well the fuse is good but i put a new one in anyway. brake light is not stuck on so its not the foot pedal switch. open up the switch compartment and the little piece that always seems to break that sits in the slot on the brake handle is not broken. dont see a crimped or broken wire , but how would that happen if it was never messed with.
so i am stumped. when i turn on the switch on the dash it lights up red like it should, but when i engage the switch it doesnt turn green and obviously it doesnt work. the only code showing is for the cruise control fault so i am guessing its the switch ? with the fall riding season upon us and the leaves may turn color eventually i would like to have it working. if not for that, i would just wait till winter time to mess with it.
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #2 of 15 (permalink) Old 10-06-2018, 05:21 PM
texasnurse's Avatar
Any changes in grips, bars, etc. ?
Obviously something is shorting out the accessory circuit?
Or the cruise control switch is damaged
texasnurse is offline
post #3 of 15 (permalink) Old 10-06-2018, 05:36 PM Thread Starter
while sitting in the shed i also pulled clutch in light went to green. pulled brake in,light went to green. foot brake depressed, green light again.
nothing was done to it. been using it since fuse replaced sometime ago. just stopped working
2011 RG ULTRA.
CPY84 is offline
post #4 of 15 (permalink) Old 10-06-2018, 05:38 PM
texasnurse's Avatar
Did you do something prior to the fuse blowing?
post #5 of 15 (permalink) Old 10-06-2018, 05:43 PM Thread Starter
nope but that was 2 years ago
2011 RG ULTRA.
CPY84 is offline
post #6 of 15 (permalink) Old 10-06-2018, 05:45 PM
texasnurse's Avatar
Hmm seems to be working in opposite, Id bet on an ecm fault
post #7 of 15 (permalink) Old 10-06-2018, 05:59 PM Thread Starter
P0577 Code means there is an electrical fault in the cruise control circuit due to a failed switch, or abnormal voltage level in the input circuit.
2011 RG ULTRA.
CPY84 is offline
post #8 of 15 (permalink) Old 10-06-2018, 08:18 PM
Mike U's Avatar
I had the same problem with my 2012 Custom.
I found the front brake light switch was bad so I did a quick repair and all was well for a while.
When the cruise stopped working again I used the Harley diagnostic check and found the set/resume switch was faulty.
I replaced both the front brake lamp switch and the set/resume switch and all has been well ever since.
I'll list below the Diagnostic Steps I used.
Hope this helps.
Mike U.
1. Hold cruise switch in the SET position.
2. Turn the cruise ON.
3. Turn the main power switch on, the cruise light should initially come on then turn GREEN, release the cruise switch the light will turn RED.
4. Push the cruise switch to RESUME the light should turn GREEN, release the switch, the light should turn RED.
5. Roll the throttle OFF make sure you roll it off to activate the cutoff switch for the cruise, the light should turn GREEN, release the throttle
6. Apply the front brake, the light should turn GREEN, release it, the light should turn RED.
What you have done is test each of the SWITCHES that are in the cruise system.
If, during any of the tests, the light does not turn GREEN, then that part is at fault.
smitty901 likes this.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #9 of 15 (permalink) Old 10-07-2018, 03:26 AM
Did you check if you have a gear indication in your dash? I had the cruise dumping due to a CKP crank position malfunction that was making the gear indication to disappear and so the cruise control coming off because not knowing in what gear it was.
Also a lot of dirt in the neutral switch connector was making appear the N light every time the CKP was working funny
Beaver is offline
post #10 of 15 (permalink) Old 10-07-2018, 09:58 AM
Stoic Joker's Avatar
I'm thinking your problem is with the clutch switch there. Is the starting in gear behavior backwards as well? Switch may be misaligned.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 11:09 AM
Cruise control not working CPY84 Troubleshooting for Road Glides 21 04-13-2017 10:48 AM
cruise contol stopped working dhhen Troubleshooting for Road Glides 21 04-17-2012 03:29 PM
Cruise control working intermittently? motodrummer Controls & Handlebars 4 03-23-2012 07:31 AM
Cruise Not Working Hullhorr Troubleshooting for Road Glides 27 03-22-2011 09:39 PM
